08-28-2008, 09:09 PM   #1
Noise reduction: in camera or on post-processing?
I'm planning to shoot in a low ambient light and thinking of increasing the ISO to 800-1600.
In order to get the optimum noise reduction, which one is the best practices?
- apply noise reduction in camera only.
- apply noise reduction on post-processing (in-camera noise reduction is turned off)
- both (in-camera noise reduction + post-processing noise reduction).
thanks.
08-28-2008, 09:15 PM   #2
Clicker's Avatar
I would think shooting RAW then post processing?
08-28-2008, 10:22 PM   #3
mithrandir's Avatar
If you do it in camera, then the camera will be making the choice for you (and maybe not the choice you would like made). Post process lets you analyze which noise reduction (luminance, etc.) to use and how much without risking softening the picture before you see it for aftershoot work.
08-29-2008, 02:45 AM   #4
soccerjoe5's Avatar
i love the grain of just using lowest NR setting in-cam of my k20D (using jpegs). i don't do PP noise-reduction
08-29-2008, 07:54 AM   #5
QuoteOriginally posted by paulusta Quote
thanks.
I gues it's a matter of available time.
How much energy do you want to put into postprocessing your photos?
1. If you are going to work on all of them -> shoot raw, turn off jpeg.
2. If you want to store / print them right out of the cam, turn off RAW, experiment with the camera settings to your liking (sharpness, colour, noise reduction) and leave the settings alone thereafter.
3. Are you somewhere inbetween; use the last approach and press the RAW button for the ones you think you really want to do PP on and get yourself a proper piece of software.
Success,
- Bert
08-29-2008, 07:56 AM   #6
deejjjaaaa's Avatar
thanks.
PP for example can allow you (if you are willing to spend your time) to apply different noise reduction techniques/parameters/etc to different parts of the image based on what you want to achieve.
09-02-2008, 08:23 AM   #7
thanks for all the replies.
I had several shots using high ISO (1600) and after looking at the results (just raw conversion via Bibble without any noise reduction) ,
I was surprised with the noise and made me thinking,
is this still acceptable, OR
is there anything that needs to be done to improve the IQ
09-02-2008, 10:06 AM   #8
Canada_Rockies's Avatar
In camera noise reduction will lose detail in the image, and it cannot be brought back. Noise reduction blurs the image so that the noisy pixels are smoothed out. If you leave it until post processing, you have all the image details, and you can decide how much of the detail to drop out to smooth the noise.
09-02-2008, 02:31 PM   #9
Moderator PEG Judges
Kerrowdown's Avatar
Shoot raw, post process noise reduction, gives you max control of the finished result.
09-02-2008, 03:11 PM   #10
soccerjoe5's Avatar
i say try them all out and see for yourself and decide what YOU want.
but if you want the cleanest output with lots of detail, you should shoot in RAW and do your own noise-reduction in post-processing.
i am personally very happy with the noise/grain of the lowest NR setting for jpegs in the K20D in high ISOs for personal shooting.
09-02-2008, 05:02 PM   #11
troywhite's Avatar
also make sure you expose to the right. underexposure at high ISO results in nasty noise.
09-05-2008, 02:05 PM   #12
pentaxshooter's Avatar
While I sometimes enjoy the photo-like 'grain' of the 20D's output, I would recommend RAW and photoshop.
09-06-2008, 12:22 PM   #13
On my K10D I have in-body NR turned off, shoot RAW and post process in LightRoom with custom levels (usually not a very high setting).
camera, dslr, in-camera, noise, photography, post-processing, reduction
Lens Correction: 15mm DA Limited (in-camera Pentax Kx processing or post-processing?) ADHWJC Digital Processing, Software, and Printing 10 11-29-2010 08:11 PM
In-camera noise reduction in the K-5 PALADIN85020 Pentax K-5 8 11-05-2010 11:09 AM
Does in camera noise reduction actually work? I think not. KxBlaze Pentax DSLR Discussion 14 09-24-2010 06:29 PM
Noise reduction - in-camera vs DCU Mullah Digital Processing, Software, and Printing 2 12-22-2009 02:30 AM
Noise Reduction and Raw Processing Kemal Pentax DSLR Discussion 10 09-06-2007 08:10 AM
All times are GMT -7. The time now is 03:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
