Originally posted by jumbleview weather-resistance works ! Unless it doesn't. The main problem is that, there is no strict technical definition under which conditions it should work and under which it should not. Some got lucky to survive strong rain, some got unlucky to get water inside after occasional splash. If your camera has a big value for you and you cannot afford to buy a replacement at once, better to be careful.
from Pentax:
Dustproof, weather-resistant construction
to assure solid performance under demanding outdoor conditions
The K-3 features a dependable dustproof, weather-resistant construction to prevent the intrusion of water, moisture and dust into its interior. A total of
92 special seals are applied to the crucial areas of the K-3 body, including control parts, panel joints and cover hinges, to assure an airtight body. The optional D-BG5 Battery Grip also features the same weather-resistant, dustproof construction.
AW/WR-series lenses
to complete the weather-resistant, dustproof digital imaging system
To optimize the benefit of lens interchangeability, PENTAX offers an extensive lineup of the weather-resistant, dustproof AW and weather-resistant WR series.
* AW stands for All Weather; WR for Weather Resistant;.
Feature 4?K-3 | RICOH IMAGING
of course some of that could just be " puffery "
but don't confuse Water Resistant with Weather Resistant
and from a member's reported email with pentax, there is the following:
official statement from Pentax on WR
To quote Pentax
" There is no standard/classification of weather resistant, because it is not waterproof product.
Weather resistance is a material's ability to hold up against deterioration from exposure to harsh elements.
This may include strong sun, wind, rain, humidity, snow or extremely hot and cold temperatures.
Although a material may be determined to be weather resistant, this does not mean that it will not incur any damage.
You can find more detail information how to carrying the camera in the operating manual page 147 "
Read more at: Ks2-warranty and water - PentaxForums.com
Read more at:
https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/359124-k3ii-fai...#ixzz54FeU9uyM
