09-02-2008, 06:36 PM   #16
danielchtong's Avatar
QuoteOriginally posted by Canada_Rockies Quote
In the flash family, "auto" means that the flash will compensate for distance/subject brightness. You do not have to manually use guide numbers to determine the aperture to use. You do not have to manually set the camera to the synch speed.
When the description does not include the letters TTL, then the flash uses its own sensor to control the output of the flash.
I hope this clears up the confusion.
Very detailed explanation of the use of the flash - I love it for a diff reason.
Also my apology to Busiko as well .
I was referring to the question of the OP (re k200d) and the flash can be considered as 'auto' particularly in relation to some of late models of film cameras and its use as a standalone unit.
Hey we all learn from other forum members
Daniel
09-05-2008, 07:43 AM   #17
nutkasse's Avatar
hi all,i tried the flash set on auto(not ttl) & used a 50mm/1.7 lens & it work out well.shutter speed was set @125 & aperture set around f8
now i wonder if the af200s will work???
geoff
09-05-2008, 10:48 AM   #18
Busiko
Guest
QuoteOriginally posted by danielchtong Quote
Daniel
Hello Daniel. I'm glad that the light came over that matter. And I see no need for apologies.
QuoteOriginally posted by nutkasse Quote
geoff
Hi Geoff, the same applies to the AF200S flash, Auto or Manual will do. It will work fine, although with less Power (=shorter distance/wider aperture) , and check that the shoe voltage is no higher that 10Volts which I believe is OK.
Rui
09-05-2008, 04:07 PM   #19
nutkasse's Avatar
hi busiko. how do u measure the voltage? which terminals & which is positive & which is negative?
thks
geoff
09-06-2008, 07:53 AM   #20
Busiko
Guest
thks
geoff
With a voltmeter, it should read around 7.5V between the side contact(-) and center contact(+). The AF200s should be OK I presume. But if you have the chance confirm before attaching it to the camera.
Rui
09-06-2008, 08:08 AM   #21
nutkasse's Avatar
hi busiko,the voltage is 5.7X volts. so this can b used!!
thks
geoff
09-06-2008, 08:19 AM   #22
nutkasse's Avatar
also unomat bc38t flash voltage between centre pin & ground is 4.41v. is this safe 2 use??(too many flashes!!!). on auto & manual mode
geoff
09-06-2008, 11:06 AM   #23
Busiko
Guest
geoff
Yes, every thing below 7~8 volts is safe. If you get remote triggers for them, you can use all at once and play with Lighting and shadows.
Look here for great info on Flash Lighting.
http://www.strobist.blogspot.com/
09-06-2008, 03:58 PM   #24
nutkasse's Avatar
thks busiko
geoff
camera, dslr, photography
For Sale - Sold: Pentax AF 280T Flash Chris S Sold Items 4 03-12-2010 06:39 AM
Loose flash battery compartment door (AF-280T) iht Troubleshooting and Beginner Help 5 02-01-2010 07:48 AM
K200D and AF 280T drogheda99 Pentax Camera and Field Accessories 4 08-01-2009 03:04 AM
For Sale - Sold: Like New Pentax AF-280T Flash LX60 Sold Items 4 03-04-2009 06:49 PM
All times are GMT -7. The time now is 01:42 AM. | See also: NikonForums.com, part of our network of photo forums!
