02-02-2018, 09:22 AM   #1
Weather sealing on older Pentax cameras.
Hope this is the right place for this question. Can anyone tell me how well the weather sealing holds up on older model cameras such as k10d and older WR lenses? If they sit for
a long time ( months, years ) do the seals dry out and become useless in say rain? I hope this has not been ask before.
Thanks in advance.
02-02-2018, 09:54 AM   #2
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by jer1 Quote
Thanks in advance.
this might be a good thread to review
About those WR body weather seals...User responsibility and best practice - Page 2 - PentaxForums.com
one member's experience
" 4 Pentax DSLR bodies over 15 years, and no issue with weather sealing. "
Read more at: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/351252-about-th...#ixzz55yFg226b
02-02-2018, 10:34 AM   #3
Alex645's Avatar
Theoretically, they do degrade over time, but in my decades of owning cameras with weather-sealing, time is much less a factor than if the camera has been repaired or serviced.
Again theoretically, the tech that re-assembles the camera or lens after repair should and would ensure all seals have integrity and are back in place, but I've found it's not 100% again.
Probably the weakest link is the silicone gasket on the lens mount. If you swap lenses often, it's a good idea to use some silicone based lubricant on that gasket before your next 'Safari'.
...and yes, this has been asked before, and it will be asked again, but as they say, reduce, reuse, recycle.
02-02-2018, 10:55 AM   #4
Not a Number's Avatar
Yes, the seals dry out or flatten with age. The seal on the jack door on my K10D is quite flat and I don't trust it to seal properly.
02-02-2018, 01:41 PM   #5
QuoteOriginally posted by Aslyfox Quote
Read more at: About those WR body weather seals...User responsibility and best practice - Page 2 - PentaxForums.com
Thanks, Lot of good advice.
---------- Post added 02-02-18 at 12:48 PM ----------
Would silicone used sparingly and applied by hand "revive" the seal?
---------- Post added 02-02-18 at 12:59 PM ----------
Thanks Alex645,
I replied to NotANumber about using silicone as you suggested, can it be used on any gasket that is easily accessed on the camera? Just wondering>
02-02-2018, 08:26 PM   #6
Alex645's Avatar
Thanks Alex645,
The best and costly solution for really old seals is to replace them. But I think a silicone grease like Danco 88693 Silicone Grease, would help extend the life of any o-ring or gasket. Petroleum based lubricants can harm plastic and any rubber parts, so thatʻs why Iʻd suggest a silicone based grease. Itʻs food grade, so Iʻd just use my finger and use sparingly.
Any gasket easily accessed on the camera? Like the battery, memory card, port compartment doors? I donʻt see why not as long as you donʻt get to zealous; less is more. I wouldnʻt disassemble the camera to lube it unless I had semi-pro repair experience and skills...which I donʻt.
body, camera, dslr, gasket, hope, lens, photography, practice, responsibility, silicone, time, weather
Another weather sealing question ;-) jonn47 Pentax DSLR Discussion 26 09-18-2017 09:43 PM
A short story about the K5 weather sealing cxzj Pentax K-5 & K-5 II 25 05-25-2017 05:39 AM
weather sealing experience with K5 tibbitts Pentax DSLR Discussion 11 12-05-2016 07:14 AM
Weather-sealing and the Pentax 645z Gurdur Pentax Medium Format 10 08-10-2016 11:05 AM
k3II and the weather sealing Greenneck Troubleshooting and Beginner Help 60 08-07-2016 03:12 AM
All times are GMT -7. The time now is 01:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
