Originally posted by Kemal This is extremely annoying. I picked up the K10D in the hopes of using some great manual Pentax lenses I have, only to find there are exposure problems and things are not metering well because the camera doesnt know what f-stop the lens is at in M mode.
I called Pentax about it and that was fruitless.
Is this a solution? I was reading on the Pentaxuser UK forum that if you use the DPOF button by the on/off switch and read the EV bar and use the scroll button to reach the center of the bar then take a picture of your subject...would that work in make a good exposure using a manual lens?
I tried it out and the exposures were better than using the green button, but I can't inspect them on a screen right now and the histogram is sitting on the fence in showing a proper exposure.
I don't want to buy new lenses and this camera was advertised as being able to be backwards compatible with manual lenses. How could they have overlooked this? Short of a new firmware or focus screen switch- has anyone had success in using manual lenses properly?
I have use manual lenses successfully. First make sure that that "use aperture ring" is on in the "C" menu. If your lens has "A" function, it is not the same issue.
Select manual focusing (below RAW button) on front of camera and select "M" on top dial. Frame, manually focus (green indicator and beep if focused) and set desired aperture for DOF, press green button to see camera exposure speed. If shutter speed to low either increase ISO or aperture and press green button to see new speed. On the other hand you can use front dial to change shutter speed but this will change the image to darker or brighter. If happy. snap image.
It took me about a minute to change to a manual lens, 50mm f1.7, change ISO and WB , switch to manual mode and take a picture.
It is very close to a manual camera but instead of instant feedback from a light sensor which require to manually change speed or aperture, the green button set your shutter speed based on your settings, aperture and ISO. You have to make a decision to either change ISO or aperture to achieve the desired image results if you are not happy with speed, i.e too slow. Always press the green button to see the shutter speed prior to taking an image is a good habit unless you desire to change the shutter speed using the front dial to adjust brightness, pressing the green button after that would simply reset speed. Hope this help.
