Originally posted by Infinite Ascension There is already some info found here.
Pentax K-3 Review - Recommended Settings | PentaxForums.com Reviews
But I feel that a lot of user specific input is missing from people who have owned and been using the k3/ii for a good while to get a really great hang of it.
What are people's thoughts on the settings stated in the link above?
I use most of the recommendations except:
- Both highlight and shadow correction OFF. The "magic" of these settings are a common source of user confusion.
- Focus peaking OFF in live view. Depending on subject contrast, the "peaked" range may define a fairly broad range of distances resulting in poor focus precision. Edit: I am, however, a big fan of magnified live view (at full resolution, 1:1 pixel-to-pixel) for fine focus. This allows one to leverage the full resolution of the lens to place fine focus at the exact point desired with no ambiguity.
- Center AF point for live view. I find it easier to focus and recompose rather than fiddle with shifting the AF point to be "just right".
- Leave RAW/Fx at default setting (only because I don't have a strong need to have it otherwise)
- Movie mode settings for full manual (again, this suits my needs, but may not work for others)
- Dust remove on start-up/shutdown OFF. I do this to mostly save battery, though it may make sense to it ON in dusty regions.
- Bulb mode option...varies according to the type of remote or external intervalometer I am using. For example, the IR remote app on my phone works best with option 2. My wired remote is more predictable with option 1.
- I have NO custom image customizations and generally use the "Natural" option
Originally posted by Infinite Ascension What about this link: RiceHigh's Pentax Blog: My Best Optimal Custom Image (Colour) Setting Combination for the Later Pentax Digital Bodies
Custom image settings are fine, but they are limited to JPEG only* and are biased by the characteristics of the camera's rear LCD (somewhat higher contrast/saturation than a properly calibrated computer monitor). As for RiceHigh's suggestions...If he likes them, that is fine. What works well for you might be something else. I don't use that feature.
Originally posted by Infinite Ascension What settings should I be setting my camera for sunset city shootings if all I got is 35 prime f2.4, 50 f2, and 50-200 wr?
Hmmmm...that is a loaded question in that only you know what you are wanting to accomplish. The short answer drawn from my experience with the K-3 and K10D prior to that:
- Shoot RAW
- If one must create JPEGs for sharing straight out of camera, shoot RAW+JPEG or develop in-camera on a per image basis
- Know and apply the principles of exposure
- Tune your image to fit your vision using a computer in "Post Processing"
That last point is the most important. One's computer is the digital equivalent of a color darkroom and creation of an appropriate rendering for a print or on-screen viewing is helped immensely by doing the hard stuff out-of-camera. There are several high quality options for doing this "post processing" that vary in price from free to $$$. My preference is Adobe Lightroom 6 for RAW processing, cataloging, and print management and Affinity Photo for raster editing (Photoshop stuff).**
There you go! Have fun and enjoy getting to know your most excellent K-3II
* Custom image, lens correction, sharpening and most other in-camera process settings are generally limited to in-camera JPEG and TIFF images. With a single exception, the Pentax Digital Camera Utility (PDCU) that was bundled with your camera, RAW processors do not decode those settings while processing RAW data. The one setting that is generally honored is White Balance and even then, the value applied may not be exactly the same as set in the camera.
** I hesitant to recommend Lightroom due to Adobe's movement to a full subscription model. At present, one can still buy a standalone perpetual version of Lightroom 6 for $149 USD but with no updates beyond the v6.11 download. The current availability is a reprieve of sorts. The standalone was supposed to disappear completely 1/1/18.
