Show Printable Version 23 Likes Search this Thread
02-23-2018, 12:30 PM   #1
str8talk83's Avatar
K3 vs K3 ii for wildlife
I am a long time lurker but have never actually owned a Pentax digital camera. I shoot with Sony a7 and am happy with it for my general photography needs.
The one area it’s lacking is for wildlife photography. I’m wanting something to use on a kayak and the weather sealing of the Pentax system has always impressed me. I think I’m going to go with the DA 300 and one of the K3 cameras for the best price to performance ratio.
Is the AF actually better on the k3ii? I know it’s advertised as improved, but I wondered if it actually is. I’m concerned mostly with tracking.
02-23-2018, 12:36 PM   #2
QuoteOriginally posted by str8talk83 Quote
It is better, specifically when the distance between you and your subject changes rapidly. The core hardware and speed remains unchanged, but if you find yourself shooting nearby wildlife, then the K-3 II's enhancements (also found in the KP and later models) will improve your keeper rate.
02-23-2018, 12:46 PM   #3
str8talk83's Avatar
Thanks for the insight.
02-23-2018, 12:55 PM   #4
Seeker of Knowledge
aslyfox's Avatar
I believe that I have seen some posts from members who canoe or kayak
perhaps you could do a search and find them
they might have an opinion
02-23-2018, 12:56 PM - 2 Likes   #5
jacamar's Avatar
I shoot wildlife with the K-3 and the DA*300mm, usually with the HD 1.4x teleconverter (also weather resistant). The TC is a significant additional cost, but it works well with the DA*300mm and the extra reach really helps as long as you have a reasonable amount of light. Put it on your "wish list" at least!
02-23-2018, 01:32 PM   #6
str8talk83's Avatar
QuoteOriginally posted by Aslyfox Quote
I'll try to find that thread, thanks.
02-23-2018, 02:17 PM - 2 Likes   #7
I hope no-one minds me saying this.... Pentax has many amazing attributes and I love my camera. But you mention AF tracking is a priority for you. That isn't Pentax's strong suit. If you don't already have a lot of Pentax lenses - it might be better to look at a NIkon body.
They may lack some of the high end image quality features of Pentax - but they can be found with weather sealing and the consensus seems to be they have the best AF for wildlife.
That said I've happily taken pictures of stationary birds from my canoe using the K-S2. I wouldn't fancy my chances with them in flight though.
02-23-2018, 02:47 PM   #8
str8talk83's Avatar
QuoteOriginally posted by ks2user Quote
Thanks for your honesty. AF has been the only hangup I've ever really had with Pentax. I was hoping it has improved. When I first got into photography, I ended up going with Canon for that reason. I had to sell all my stuff after a bad financial time and when I came back I had the full frame itch and went Sony.
02-23-2018, 03:05 PM   #9
jatrax's Avatar
One advantage of the K-3II over the K-3 is the built in GPS. For my purposes GPS is essential to be able to locate the site of a photograph. YMMV of course.
As to AF, there was a significant improvement in the K-3 models over the K-5 models. Will it stand up to a modern Nikon in the tracking area? Probably not. Will it work well enough to get good photographs? Yes, though you may have to practice a bit and also set up the options properly for tracking which sadly are not documented well.
02-23-2018, 03:31 PM   #10
jpzk's Avatar
For BIF and other such things, I have found the K3 quite suitable, thank you.
Of course, the AF may not be Pentax strong point but it is also a matter of user's technique.
For further references, you may want to have a peek at some pictures taken with several "grades" of Pentax K's (you're welcome to peek at my Flickr hereby included in my signature) ... as far as I am concerned,
Perhaps it would be a good idea not to make unfounded "observations" with regards to the K3.
02-23-2018, 03:44 PM   #11
str8talk83's Avatar
QuoteOriginally posted by jpzk Quote
I agree that it's best not jumping to conclusions. I'm actually considering renting the combo and seeing what I think. It would be my first rental, but it might be worth it in this case. If I can make the Pentax system work for me, it provides the best budget friendly option with the weather sealing I'm looking for.
02-23-2018, 04:17 PM   #12
normhead's Avatar
The K-3 has been my wildlife lens for the past 3 years. But, I have no experience with the K-3II os can't help you out there.
I do a lot of canoeing, I work as guide in the summer. My travel kit for boating is usually the DA 18-135 and DA*60-250 with HD DA 1.4 TC in a Pelican case that I can slide under my seat.
02-23-2018, 04:38 PM   #13
str8talk83's Avatar
I do a lot of canoeing, I work as guide in the summer. My travel kit for boating is usually the DA 18-145 and DA*60-250 with HD DA 1.4 TC in a Pelican case that I can slide under my seat.
That sounds like it would be a good combo. I use a Native Ultimate which is similar to a canoe and I also have done a lot of canoeing with a camera. I used to work with youth in a residential treatment facility and we would go on 3 day canoe trips on the river (I was in Missouri then.) I would take photos of the kids and their families loved it. A lot of good times.
02-23-2018, 04:48 PM   #14
Seeker of Knowledge
aslyfox's Avatar
One advantage of the K-3II over the K-3 is the built in GPS. For my purposes GPS is essential to be able to locate the site of a photograph. YMMV of course . . .
with the K 3 II, you lose the built in flash completely
with the K 3 and the add on accessory, o-gps1, you only lose the flash when you use the add on GPS unit
Pentax O-GPS1 reviews - Pentax Camera Accessory Review Database
Pentax O-GPS1 GPS Unit Review - Introduction | PentaxForums.com Reviews
otherwise you have a built in flash
02-23-2018, 04:49 PM   #15
Renting is a good idea. I presume you know the K-3 has been discontinued for a while, being replaced by the K-3 II, which has a built-in GPS instead of a flash. Now it too has been recently discontinued, so remaining stock is offered at a low price as an outgoing model.
There is a fairly substantiated rumor of a new replacement model in the works, and we expect an announcement sometime this year.
As to AF, an advanced tracking system has been more linked to fast-action sports as a matter of concern, where a subject of interest might move off to the side of the frame by the time the shutter fires. I don't think this would be an ideal shot for a BIF, which requires the skill of the photographer to follow the action well, in order to get good framing. I have seen numerous examples posted on these forums of excellent BIF shots taken with Pentax DSLR cameras, using various lenses. The lens is also a major factor as to AF speed and efficiency.
camera, dslr, k3, k3 vs k3, pentax, photography, vs k3 ii, wildlife
AF improvement K3 & 50-135* vs K3 & 70-200* vs K1 & 70-200* for basketball? RedBoomer Pentax SLR Lens Discussion 13 07-25-2017 12:06 PM
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 & K-5 II 2 06-28-2017 04:59 PM
Pentax K3 ii vs Canon 5D mark ii mogge Welcomes and Introductions 49 03-27-2016 02:39 AM
Enthusiast vs Prosumer vs Semi Pro vs Pro vs APSC vs Full Frame mickyd Pentax DSLR Discussion 10 11-12-2013 07:14 PM
Camera comparison: One X vs Galaxy S II vs Nexus vs N8 vs iPhone 4S jogiba Canon, Nikon, Sony, and Other Camera Brands 3 04-12-2012 07:41 AM
All times are GMT -7. The time now is 02:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
