02-25-2018, 05:54 PM   #1
bobell69's Avatar
Software Support for Pixel Shift
Just wondering if either On 1 or Adobe Software supports Pixel Shift images as yet? I find Silky Pix to be very unfriendly and buggy
02-25-2018, 07:05 PM   #2
Mikesul's Avatar
QuoteOriginally posted by bobell69 Quote
Do you mean the real Silky Pix or the Pentax bundled software (DCU)? The are not the same. ON1 does not and Adobe has weak support. Most people like Raw Therapy..
02-25-2018, 08:55 PM   #3
may be look into Rawtherapee; available for both Mac and Windows, and free.
02-25-2018, 09:31 PM   #4
aleonx3's Avatar
I gather you mean the software bundled with the camera, and not the Silkypix Developer Studio pro 7.0.4 version that supports pixel shift resolution images from k-1.
02-25-2018, 09:34 PM   #5
Raw T!!
Also very friendly to Pentax HDR shots. Export as 16 bit TIFF to your favorite software.
02-25-2018, 09:39 PM   #6
twilhelm's Avatar
Rawtherapee has what I believe is the best support for pixel shift images.
02-26-2018, 12:50 AM   #7
+1 to Raw Therapee
+2 that its free
Quite a bit of re-learning, but if you stick to the basic controls, its not too hard to learn.
02-26-2018, 07:16 AM   #8
naward001
Guest
I'm confused, I've been developing Pixel Shift images from my K-1 through Adobe Camera Raw pretty much since I got it, what am I missing?
I know that there is some support because I have tested PS/non-PS images of the same scene in the software to see the differences and there is a very clear advantage to the PS files.
02-26-2018, 08:04 AM   #9
Not a Number's Avatar
I wonder how long it will take for Rawtherapee to support dynamic pixel shift?
02-26-2018, 08:33 AM   #10
twilhelm's Avatar
QuoteOriginally posted by naward001 Quote
Adobe does support pixel shift, but not to the extent rawtherapee does. There are others more versed on its capabilities than I am, but I know you have control to adjust each image before combining.
02-26-2018, 09:20 AM   #11
bobell69's Avatar
I was referring to the Silky Pix software that came with my K3II. I have downloaded rawtherapee as suggested and will give it a try. Has anyone developed a step by step suggested processing of a Pixel Shift image using Rawtherapee? Would save a lot of time experimenting. Thanks for all of your replies to my post.
02-26-2018, 10:04 AM   #12
As far as I know Adobe can't handle movements in the picture, so as long as everything in the picture is static it will be fine.
But if anything moves you will end up with artifacts. To mask out movements Rawtherapee is the best package around. Again, AFAIK.
02-26-2018, 10:21 AM   #13
That will depend on how helpful the early adopters of the K-1 ii are. RT relies on helpful users willing to supply files and participate in discussions.
02-26-2018, 10:50 AM   #14
naward001
Guest
QuoteOriginally posted by Gimbal Quote
Gotcha, I'm mostly shooting scenes without motion. When I suspect that there will be motion in an image I make sure to shoot a non-PS image for backup and as a source for unaffected pixels. Although, when I've found artifacts in my PS images so far, I've very easily been able to clone them away from information elsewhere in the file; this of course is made easier because of the subjects that I tend to work with.
My point being, I've never felt that I was limited by developing my PS images through ACR. I do tend to do the bulk of my processing in Photoshop though, so I understand that other workflows may benefit from the additional controls offered by different software.
02-26-2018, 11:37 AM   #15
So, Lightroom and ACR will process RAW pixel shifted images, but any place there is even a tiny amount of movement in the image, they will produce artifacts. If you wish to have motion correction in the image the top options are the Digital Camera Utility (DCU) that is put out with Pentax cameras and Raw Therapee, which is free and downloadable from the interwebs.
I use pixel shift quite a bit and my typical process is to run my DNGs through Raw Therapee to generate a TIFF file that I then finish processing in Lightroom.
This is a crocus shot with pixel shift. There wasn't very much movement as it was a still day, but there was just a little bit of artifact that I could see along the edges and using Raw Therapee took care of that. Processing it directly in Lightroom would have magnified those artifacts.
camera, dslr, photography, pixel, shift, software, software support, support for pixel
K1/Samyang 24mm Tilt/Shift and Pixel Shift DDoram Pentax K-1 & K-1 II 6 12-14-2021 06:47 PM
Rawtherapee adds support for pixel shift files interested_observer Digital Processing, Software, and Printing 6 03-26-2017 04:10 AM
Advancing the Ball: Review of "Pixel Shift" in Different Software Michaelina2 Digital Processing, Software, and Printing 5 06-18-2016 08:43 AM
Lightroom support for Pixel Shift RAWs Zen4Life Pentax K-3 & K-3 II 4 03-10-2016 02:56 PM
Which Support for K3II Astrotracer or Pixel Shift Feature Use C_Jones Pentax Camera and Field Accessories 33 11-25-2015 12:40 PM
All times are GMT -7. The time now is 05:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
