Originally posted by Gimbal
We can only speculate, but as I understand it (which might be way wrong) it kicks in on images above iso640, which means it indeed can pass the image through without "working" on it.
We know that it reduces noise, increases Dynamic Range, and enhances color - we don't know whether it does anything else; we don't know whether it truly is idling in 'pass through' mode below ISO 640 and/or whether these different functionalities are turned on / ramped up one-at-a-time up to ISO 640. We also don't know whether 'not working on data' is a result of a switch the processor throws or whether its programming causes different behaviors at different ISO levels.
The fact that it now can't be turned off is probably a design decision they made to hide the "true" performance and nothing else.
'Design Decision' doesn't mean that they
could turn it off; I'm not sure what you mean by 'true' performance. Proper design could mean that it works best when data is always flowing through it, that in some kind of 'off' mode it would degrade the image.
