09-03-2008, 02:58 PM   #1
DOF preview problem
I've tried to use the SMC PENTAX-M 1:1.7 50mm lens on my K200D, but sadly the optical preview doesn't work. I can hear that mechanism itself moves, but aperture stays in place. Interestingly, when I shot, aperture moves, but even more interestingly I don't see effects in a picture! No matter what aperture is set, a picture always looks the same (same DOF and histogram). As if aperture moved after a picture had been taken (or much before). Does anyone of you came across similar problem?
It is worth noting that lens works on my Pentax LX.
Kind Regards,
Pusiek
09-03-2008, 03:38 PM   #2
Are you in "M" mode? I don't have my camera with me to confirm my memory, but I recollect that DOF preview for m-series lenses only works if you are in "M" mode.
09-03-2008, 03:46 PM   #3
QuoteOriginally posted by Pusiek Quote
My K10D had an issue with the aperture mechanism. I sent in in for repair after confirming the aperture mechanism didn't work by setting the aperture to 22 in Manual mode, and noting the aperture blades did not move when viewed through viewfinder and using optical preview. There should have been a very noticeable difference in the amount of light, but the amount of light in the viewfinder remained the same. I also noted the aperture blades from the front of the lens in bulb mode and f22, also didn't move when activating the shutter.
Thank you
Russell
09-03-2008, 04:18 PM   #4
Marc Sabatella's Avatar
The aperture on manual lenses always stays wide open on Pentax DSLR's - whether doing DOF preview or actually taking a picture - unless you are in M mode. M mode is the only one in which the aperture ever closes down with manual lenses - and then, only when doing DOF preview, hitting the green button to force a meter reading and set shutter speed, or when actually taking the picture.
09-04-2008, 02:05 PM   #5
Thank you.
I didn't notice, that I need to be in M mode for this type of lens. It works fine now.
Kind Regards,
Pusiek
aperture, camera, dof, dof preview, dslr, lens, moves, photography, picture, preview
DOF Preview jensp2m Troubleshooting and Beginner Help 4 06-02-2009 11:52 AM
How does DOF preview function? Heldur Pentax Film SLR Discussion 11 10-20-2008 10:29 AM
k20 dof preview bimjo Pentax DSLR Discussion 3 03-14-2008 05:03 PM
cant access DOF preview. Akcelik Pentax DSLR Discussion 5 03-07-2007 01:42 PM
DOF Preview not working? Akcelik Pentax DSLR Discussion 0 03-07-2007 08:51 AM
All times are GMT -7. The time now is 03:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
