I've never used the 15-30mm, but I would not be satisfied with those results. I don't know if the problem is with the lens itself, but pixel peeping at 100%, nothing really looks crisp to me. I checked some shots I've taken with ultrawides on a K-5 II and they seem significantly sharper. (The pixel pitch of the sensor is about the same as the K-1, so I think they should exhibit similar sharpness at the pixel level.)
Here are some thoughts on possible explanations:
1) Autofocus failed to get a lock and left the lens at the minimum focus distance.
I used exiftool to look at the DNG file, and the data shown included:
AF Predictor : -1021
AF Defocus : 7
I didn't find any documentation for the AF Predictor value, but the value seems kind of large to me (even though I don't know anything about it
), so I'm wondering if this was an autofocus issue. If autofocus isn't working correctly, it could indicate a problem with the lens, but I think you'd need to do some more testing to get a better sense of what the problem is. You could use a tripod and compare the results from phase-detect AF through the viewfinder and contrast-detect AF using Live View.
2) Shutter shock and/or mirror slap vibrations
I had noticed that the shutter speed was 1/125th, which is in the range where shutter shock has been reported to occur with the K-1 (and probably other cameras as well). You could try shooting with different shutter speeds to see if it makes a notable difference in your results. Try speeds of 1/250th and up to see if that helps. Results could be different with hand-holding vs. on a tripod. You can also try mirror lock-up and compare that with the electronic first-curtain shutter option for Live View (or shoot a Pixel Shift image, which uses the fully electronic shutter).
The shutter shock issue is lens-dependent. I don't know if people have reported issues when using the 15-30mm, but I suppose any lens could be significantly affected if there was something loose inside.
Later update: As I looked through more of my K-5 II photos with ultrawides, I found more that weren't as crisp as the first ones I looked at. I do think you should be able to achieve somewhat better results with the 15-30mm lens, though.
