03-12-2018, 07:20 PM   #1
Pentax K-3 in-camera infra-red effect?
With my old Pentax K-7 there was a setting that provided a in-camera infra-red (with the camera set to B/W) effect but I can't seem to find that function/setting in the Pentax k-3.
Does the K-3 have that, and if so, where is it located?
Thank you!
Theo
03-12-2018, 07:36 PM - 1 Like   #2
jimr-pdx's Avatar
It was a digital filter effect on the K-5, I also enjoyed the results. Hope a K-3 user has your answer!
03-12-2018, 07:38 PM - 1 Like   #3
There is- go to the B&W custom image preset as before, press info, and under filter effects (the first slider), select infrared, which should be the last one.
These screenshots show where you should be looking (obviously the settings are different for color shots):
03-12-2018, 07:50 PM - 1 Like   #4
Thanks Adam!! That's great. Fantastic forum. Within 10 minutes I had an answer. Maybe your answer should be a sticky as there are quite a few posts on here about doing infra-red photography. While this is not technically infra-red, the image looks exactly the same and it is a much easier solution than using filters and converting the camera to infra-red.
03-12-2018, 09:58 PM   #5
joergens.mi's Avatar
But this is only fake and has nothing to do with infrared photography.
03-12-2018, 11:20 PM - 1 Like   #6
QuoteOriginally posted by joergens.mi Quote
True. It is only a SIMULATION but for the person who just wants to get that infra-red look just occasionally it might be helpful, without having to invest in filters or conversions.
03-13-2018, 12:30 AM - 2 Likes   #7
QuoteOriginally posted by Theov39 Quote
I got my hands on a converted k10d & must say it looks quite different than the in-camera simulation.
Not saying that the in camera simulation can't look good though as far as b&w is concerned..
03-13-2018, 12:42 AM   #8
QuoteOriginally posted by grispie Quote
Yes, it doesn't look exactly the same as it is only simulating the effect but I had some nice results with my K-7. The ideal of course is a converted camera but that is quite an expensive option.
03-13-2018, 02:45 AM - 2 Likes   #9
Obviously it is hampered by the fact that the actual infra-red light information is missing in its entirety, that's a given. However, you can achieve a much better look in PP - On1 for example has a pretty good looking IR preset that gives an image that looks very similar to (an) IR image, even if not (the) IR image you would have got using an IR camera. You also have control over the various colour responses, contrast, grain, etc that you don't have in-camera, plus the output is RAW so you can further process.
For some the process is the goal, but for those that like the look but non the faff, it's a good option.
camera, dslr, in-camera, infra-red, k-3, k-3 in-camera infra-red, pentax, pentax k-3 in-camera, photography
Do any of u have experience using infra-red filters? fstop18 Pentax DSLR Discussion 3 02-15-2017 07:06 PM
Abstract Infra-red Test Draig Photo Critique 4 06-01-2014 02:32 AM
K20D Infra-red jcool Photographic Technique 2 11-06-2010 11:10 PM
How to convert a *Ist DL2 into a Infra Red camera RonHendriks1966 Pentax DSLR Discussion 3 07-31-2010 08:26 AM
How do i associate 540FGZ to K100D via infra-red wireless? MRBHV Pentax Camera and Field Accessories 10 01-13-2009 01:33 PM
All times are GMT -7. The time now is 05:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
