As others have pointed out, I also use TAv for outdoor sports and action, but also for concerts. If you are using similar shutter speeds all the time, you can probably mimic most of TAv's advantages with P + fast increase of ISO + shallow dof / action program curves (but that's a lot of settings
TAv is my main choice for concerts, especially those with dynamic lighting. For example, with a 50/1.4 lens I shoot wide open only when the light is so bad it will not allow anything else; otherwise I'll prefer deeper dof. In so-and-so light, I often change my shutter speed depending on how much movement there is, to squeeze into a lower ISO. With P-hyper this would discard my aperture setting. (If light is really really low, I then just use M set wide open, shutter around 1/60-1/125, ISO 800 and pray something can be recovered in post...)
