09-04-2008, 12:02 AM   #1
wireless with k10 and 360 fgz
Hi, if anyone can tell me how you can wirelessly shoot with the k10 i would appreciate it. I was under the impression after i downloaded ver 1.3 firmware i would be able to use pentax 360 kinda like nikon's cls system. If i was wrong i am so selling this thing!!=(
09-08-2008, 06:40 AM   #2
I shoot wireless with K10 and 360, it is easy.
Check out the tutorials here :
PENTAX Digital SLR - The New Classic
And here is another recent thread :
https://www.pentaxforums.com/forums/general-pentax-photography/36533-flash-photography.html
Next time try a search
09-08-2008, 07:05 AM   #3
Use the third tutorial on the Pentaxdslr site.
I keep forgetting to set the wireless mode using the function button, check that.
My 360 and K10D work fine in wireless,.
Dave
09-08-2008, 08:07 AM   #4
Zebooka's Avatar
First of all, small tips:
1) Mount flash on-to camera. Select desired Channel on flash.
2) Select in camera menu Wireless-Flash (Fn->Down->W)
3) Once you've OK, you'll see CH # on top LCD panel - that is you channel number
4) dismount flash from camera. Set it to Wireless mode and Slave 1 (Slave 2 is for manual wireless, and Slave 1 is for P-TTL wireless. This can be accessed by holding LIGHT button on flash)
5) In your camera go to "Custom Setting" -> "Flash in Wireless Mode" (bottom of the list).
1 - means that built-in camera flash will act like Master flash, 2 - for Control only mode.
That's it
It is all quite easy.
09-08-2008, 08:25 AM   #5
I cant do this on my K100D, right?
09-08-2008, 12:28 PM   #6
QuoteOriginally posted by ghost Quote
If you can't, there is still the possibility to buy a long wire, or maybe use a radio trigger or other way.
camera, dslr, k10, photography
K10D and Wireless trigger of AF-360 FGZ on Stroboframe 71Matador250 Pentax Camera and Field Accessories 10 03-28-2008 03:01 PM
AF-540 FGZ vs AF-360 FGZ wiseman Pentax Camera and Field Accessories 13 01-16-2008 07:54 PM
Which Flashgun ? Pentax 540 AF FGZ vs Samsung SEF-54PZF vs Pentax AF 360 FGZ Confused Pentax DSLR Discussion 3 07-25-2007 01:01 AM
360 FGZ in wireless, rear sync, any help? scribble Pentax Camera and Field Accessories 0 06-18-2007 11:08 AM
AF 540 FGZ for wireless in concert with the AF 360 FGZ Ed in GA Pentax Camera and Field Accessories 10 05-08-2007 09:45 PM
All times are GMT -7. The time now is 04:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
