Originally posted by Markovo Lets say I want to shoot some low light scenery with my K-1 (that has the White Dot problem) and the only solution that removes the "white dots" is the build in LENR. It works, OK, but for 10min exposure I have to wait for 20 minutes to capture a single image. That's long...
LENR works the way it does because that is the best way. For maximum efficiency you want to subtract exactly those pixels which glow at the time when you shoot the real image.
If you only take one DF in advance the sensor is not heated up exactly like it is after the shot and certainly not the same way after taking say 20 shots.
It is all about heat effects.
If you want top quality results there is no alternative to LENR / DFS which is faster and more accurate.
If you go for multiple exposures and then create an median image that takes even much longer.
