Originally posted by corvin Still having fits. Just cannot get it dialed in properly.
In debug mode, my options are:
AF Area Test (0-3)
AF Area Number (0-10)
Then the FocusCorr bar
I've been messing with the FocusCorr bar (sliding scale - moving it to the right to compensate for back focus...stuck at 170um for best results, but not great) - and that at AF area 0.
I assume AF Area Number is for the 11 AF sensors.
But I have no idea what the 0-3 (4 possiblities) of AF Area Test are. And I've only been working with AF Area Test 0.
Hi Corvin,
I don't think the menu of the K-x is very different from that of the K20 and other cameras, but I don't know if that's what you mean. In K20,
The path is > Custom setting > AF Adjustement, you will find a scale from -10 to +10, remember that if the positive (+) values are sharper you are in Back Focus and vice versa,
so you have to find the one that comes closest to the sharpest 0 point, increasing or decreasing on the scale, you can reset everything,
start again from 0 and focus on the area that seemed sharper, in the previous session, take note.
* I assumes AF Area Number is for the 11 AF sensors.
I recommend using the center point and spot reading, with good lighting.
Cheers Mario
