04-14-2018, 08:03 PM   #1
Which one would you buy & why
Down the road not to far off this fall I want to but an Pentax camera. I have had several a few years back and had excellent luck with them. I do not want to get into a full frame camera. Of the cameras that are available which one would you recommend? I do mostly wildlife birds lots of lake and river settings old farm houses and car races and car shows and air planes and air races. I like to do all around photography. I will likely buy the camera with no lens and add one at the same time. I guess now its the KP, K3II and ??. looking for feedback on what you would recommend to get with your knowledge on Pentax most likely a fast shutter.
Thanks Bill
04-14-2018, 08:10 PM   #2
Journeyman Cat Wrangler
SSGGeezer's Avatar
KP has been an eye opener for me coming from a K-50 which had good low light capabilities but the KP is a high ISO monster which allows for higher shutter speeds.
04-14-2018, 08:29 PM - 2 Likes   #3
Unless you're a heavy shooter or are looking to use big lenses, I'd say the KP is the way to go until a K-3 II successor comes out. It has a nice edge in terms of image quality.
04-14-2018, 09:07 PM   #4
ZombieArmy's Avatar
The KP is the camera I'm wanting to get when prices drop. I like small cameras, and coming from the K-01 it's the perfect upgrade.
04-15-2018, 05:24 AM   #5
QuoteOriginally posted by Gold Coast Quote
... I will likely buy the camera with no lens and add one at the same time. I guess now its the KP, K3II and ??. looking for feedback on what you would recommend to get with your knowledge on Pentax most likely a fast shutter.
Thanks Bill
If you have no Pentax lenses any more, higher quality lenses are often bundled with the camera as opposed to kit lenses at a good discount. If you don't want to go top of the line, the K-70 can do 95% or more of what the more expensive KP and K-3 models can do and has the high ISO sensor like the KP as well.
04-15-2018, 05:31 AM   #6
Seeker of Knowledge
aslyfox's Avatar
have you found the tool which allows you to compare two or more camera bodies side by side
https://www.pentaxforums.com/forums/pentax-cameras-compared/?c1=Pentax K-3 II&c2=Pentax KP&c3=Pentax K-70
look under " Cameras " above where you can also find reviews by users and " in depth reviews " of the camera bodies
if you decide to look for an " experienced " camera check out what is for sale in the forum's market place
I have had good luck there
04-15-2018, 06:34 PM   #7
The KP is the best performer of current models, and is of excellent build quality, has advanced controls, as well as being of compact build design for easier portability. Like many, including myself, your photographic interests are varied, therefore a variety of lenses is likely to be in your future. A lens giving best results for landscape scenics will definitely not be the same one for birding and action telephoto shots.
If you desire a larger, heavier camera with even more on-body controls, by the time the Fall season arrives, the expected K-3 II replacement might be announced, which will also incorporate the advancements of the KP.
04-15-2018, 06:50 PM   #8
I do not see where the KP has a remote shutter release cable or IR which I must have????? I can not find anywhere if it does in there online owners manual or any where else that I have looked. I see the K3II does have IR.
Any help appreciated
Thanks Bill
04-15-2018, 06:57 PM   #9
Seeker of Knowledge
aslyfox's Avatar
Thanks Bill
" A dedicated cable release (CS-310) that connects to the microphone port can be used with the KP which lacks an infrared port and thus cannot be controlled with the handy Remote F controller (but it can be controlled wirelessly with a smart phone).
Read more at: Pentax KP Review - Specifications | PentaxForums.com Reviews
Pentax Remote Control F has worked for me on the K 3 and K 3 II
https://www.pentaxforums.com/accessoryreviews/pentax-remote-control-f.html
04-15-2018, 07:25 PM   #10
Thanks for that response. That's what I needed
Thanks again Bill
04-17-2018, 12:22 PM - 1 Like   #11
SSGGeezer's Avatar
I bought the UR-232 Tasman by Kiwi Fotos (JJC product) for about 23.00 USD that has the correct size 3.5mm jack that goes into the KP's microphone jack and unless you change the default settings, it will automatically use it as a remote trigger jack instead of a mike. The camera changes automatically when you put a remote trigger in the jack. There sadly is no IR remote with the KP, but the images make it so you won't really care.
air, camera, car, dslr, pentax, photography, races
DA35 2.4 or FA35 2.0 which one would you go for (for the K-1) and why? zeitlos Pentax SLR Lens Discussion 24 01-02-2018 01:40 PM
If you could keep only one, which one and why? Ketsuppi11 Pentax SLR Lens Discussion 9 12-14-2017 10:57 AM
If you could have only 2 lenses in the 400mm+ range, which two would you buy? Clinton Pentax SLR Lens Discussion 55 10-05-2010 09:18 PM
Last question before I buy... Kx or K7, which would you buy? DavoMrMac Troubleshooting and Beginner Help 7 02-01-2010 02:42 AM
Color K-x - Which color you like the most? Which one you'd like to buy? frank Pentax DSLR Discussion 16 11-18-2009 09:41 AM
All times are GMT -7. The time now is 01:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
