Originally posted by FHPhotographer Marc, why do you assume I didn't look to the right of the viewfinder? In fact I did, and if you had read the original post you would have seen that I did and both shots read as 0.0 for exposure compensation.
I assumed when you wrote "0.0" you meant that you had dialed in 0.0 exposure compensation (presumably while in one of the auto exposure modes), and didn't realize that this number was ignored when using M mode. I certainly wasn't meaning to "scold" you for not looking, although I realize now that it might have sounded that way.
So as far as I can, there are probably three thing at play here in explaining why the meter reading was the same:
1) If you were expecting the meter spot to follow the focus spot, you were mistaken - spot metering is always the center. But given that the picture shows you trying to center on the different fruit, I'd say that's probably *not* the issue.
2) If you were centering on the different objects and *still* got the same reading, then I'd guess maybe you underestimating the size of the spot, and your reading was actually being influenced by the background as well.
3) If you were pointing at a relatively light area of the avocado and a relatively dark area of the banana, I'm still not conivnced they *aren't* about the same value.
