09-06-2008, 10:13 PM   #1
ist-d problems
I just got in a AF-500 and Tr power pack 2. The flash worked for 2 pictures in TTL mode and then the next day i put it back on my Ist-D and nothing. It seems to lock up. I can adjust the lens( 25-80mm) and that shows up on the flash but i can not change modes or anything more. If i loosen up the flash and move it back some on the shoe i get flash but not TTL just whites everything out. I then tried it on my Ist-Dl and the same thing happened. The only shoe it works on is my old MX. PLEASE HELP. I can not afford a new af-540 or 360 right now and i hope this is just user error. i also get a CH 1 code on my Ist-d when i change camera flash settings. Further more it works fine in slave mode. i can have it across the room no problem.
09-08-2008, 07:10 AM   #2
rburgoss's Avatar
Looks like you have faulty contacts on the flash's hotshoe.
Use a standard pencil eraser to rub the contacts on both flash and camera hotshoes. If this does not correct the problem, try to get another camera (friend, camera store, etc) that is compatible (pz1p, any of the zx series, etc) to rule out your camera as being culprit.
Hope this helps..
Robert B
camera, change, dslr, flash, ist-d, mode, photography, shoe, ttl
*ist D problems updating firmware GiorgioPentax Pentax DSLR Discussion 8 06-29-2013 03:33 PM
IST-d newbie with blur problems bryankknight Troubleshooting and Beginner Help 9 04-22-2010 02:10 PM
*ist D underexposure problems Stevopedia Pentax DSLR Discussion 9 02-26-2009 07:22 PM
*ist DS known problems jdmidwest Pentax DSLR Discussion 21 05-12-2007 09:04 AM
*ist DS and Sigma Problems rangitata Pentax SLR Lens Discussion 8 10-03-2006 02:42 PM
All times are GMT -7. The time now is 05:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
