I've been hired to help take photos for the prom at the local school. I thought it'd be a good learning experience, and relatively easy due to the size of the class (quite small).
What I've learned:
1. Studio setup (2 large softboxes with Pentax 540 and 360 on standard triggers) - went relatively well, image quality is spectacular (as expected), however I did have trouble focusing with my Tamron 70-200. Thankfully I was checking every shot at 100% and did not miss the images that were out of focus, but it did add to stress levels. Switching to f3.5 helped a lot with clarity, and getting things into focus. I would be happy to swap out my Tamron to a more modern lens in the upcoming years, hopefully to a 70-200 f4 whenever that comes out
2. Event photos with DFA 15-30 - it was quite challenging. AF just didn't want to help me at all, and it wasn't even that dark inside the tent that school has set up for the dance. AF didn't want to lock on subjects I'd place the focusing area on, would focus on things in the back more often than not. I've then switched to manually focusing with the distance scale which landed me with better shots. 12" fstoppers disc knock off helped a ton with lighting subjects with a single flash (540fgz).
3. Crowning was a bit of a mess - I decided to use the DFA 28-105 for the indoor crowning, thinking that newer lens with the modern focusing mechanism would land me more keepers, but unfortunately it just wasn't effective enough getting things in focus. It was pretty dark, I definitely understand that was part of the problem, but I still was kind of expecting better results from it. I think I lost few shots because of it, hopefully I'd be able to work around it in post. Setup was not perfect, people kept flashing me and throwing the metering off as well. I see that I need more practice with using flash indoors before taking any other gigs for sure.
4. I used a single set of batteries for all my flashes, I brought like 24 batteries with me
5. I think maybe next time I'll just rent 24-70 and don't bring any other lenses with me, reducing the clutter. It was pretty challenging to keep all the gear in check while switching lenses, flashes, softboxes etc in tight spaces.
This is it so far, I'll be editing pics this week and hopefully I took enough images to make everyone happy in the end of the day.
But I'll be cautious taking another event gig for now, somehow my gear just doesn't give me enough confidence for that particular field yet
