View Poll Results: What is your job level and what format do you shoot?
Pro-RAW 227.72%
Pro-JPG 51.75%
Pro-RAW+JPG 93.16%
Amateur-RAW 15454.04%
Amateur-JPG 3813.33%
Amateur-RAW+JPG 4816.84%
Just show me the results 93.16%
Voters: 285. You may not vote on this poll
09-09-2008, 09:39 PM   #46
Kguru's Avatar
You forgot ... !!
You forgot to allow a category for me : sub-amateur + cell phone format
09-09-2008, 11:11 PM   #47
ryan s's Avatar
It took me about 7 months to switch away from jpg (back with the ol 300D)...just one day out shooting with it was all it took.
RAW FTW
09-10-2008, 02:49 AM   #48
QuoteOriginally posted by Venturi Quote
RAW - why would I want to throw out the negatives?
(cash drawer sound) *cha-ching* Adobe call the DNG (digital negatives) for a reason.
I'm doing this for fun, but a large part of that fun is monkeying around, layering things and pushing pixels in PS. The more information I toss to begin with, the less room I have to move in my post-explorations before I start to see noise/artifacts.
Unless you are unable or unwilling to afford the disk space, there is no point in not shooting raw.
09-10-2008, 03:19 AM   #49
Taff's Avatar
RAW+jpeg as in shooting raw for those go out to take images, and jpeg for those happy snappy shots
Taff
09-10-2008, 03:34 AM   #50
Since you don't have a Semi Pro format here, I by no means am a pro. I do however feel I can do the same job. I do not make a living on Photography, but have been known to shoot for pay. So I figure Semi Pro and Always RAW.
09-10-2008, 11:58 AM   #51
AndrewG NY's Avatar
QuoteOriginally posted by Canada_Rockies Quote
I have not shot jpeg with my k10d, ever. I don't shoot RAW + either. I shoot RAW only. I have used film for a very long time - since 1958 with a Yashica 35mm rangefinder - since 1961 with Pentax SLR - and I will not throw away my digital negative. The jpeg is the equivalent to the print from the drugstore. If you want a larger and more detailed output, you need the original data, be it from Velvia or Sony CCD or Samsung CMOS. Why throw away data? What a waste of your talent. Every time you save a jpeg, it loses more data. Look it up. Every time you save a jpeg, it loses data. Every time. No exceptions. Once you have done post on your jpeg, you cannot go back and undo it.
I am also a RAW shooter, but this isn't completely true as depending on how you use your software, you can go back to the original, and incremental changes don't have to be destructive.
I believe that some programs like Adobe Lightroom allow non-destructive JPEG edits--essentially they take your original, record the changes you make, and when you export from lightroom or view in lightroom, you see the modified image. To my knowledge, it will generally not change the original when used this way. Yes, it is a lossy format, so there is probably some sort of loss involved--but in this case it is a one-time loss, and you can go back to the original. This of course still doesn't make up for what the camera discarded when it threw away the raw data and only saved as JPEG.
I also don't find the RAW workflow to be nearly the inconvenience I thought it would be when I switched. In practice, I nearly always want to resize the images before uploading to web or e-mail anyway, so there are no additional steps to do this from RAW when compared to JPEG. And if I was going to print, I would most likely make some sort of adjustments first--I just don't normally have much use for a full-rez JPEG. The switch did however encourage me to replace my computer though--the old one was just too slow when processing RAW files even though it handled JPEG pretty well. (I was using ACDSee Pro at the time).
09-10-2008, 12:01 PM   #52
AndrewG NY's Avatar
Maybe poll should have another choice: "Don't shoot, just collect gear".
09-10-2008, 12:41 PM   #53
Venturi's Avatar
It seems there is a perception by some that those of us shooting RAW are post-processing fanatics. I certainly am not, if I'm in post then I can't be shooting or doing anything else. If I'm spending time in heavy duty post then I botched the shot(s) and am not happy about it either. I suspect I'm not in the minority in this regard. But at the least I am going to resize and/or crop every shot that I keep to fit the situation or use. Other than CPU cycles it takes no more work to do that on a RAW image than on a JPEG, and doing it from a RAW negative is going to produce a better quality "print" no matter what measure you use.
QuoteOriginally posted by AndrewG NY Quote
Some would argue that this is not a disadvantage, but actually an OPPORTUNITY! I'm in this boat to a degree as I've been wanting to speed up my desktop for a while and processing RAW definitely is helping to rationalize a "need".
09-10-2008, 02:05 PM   #54
ryan s's Avatar
I built my computer around photos, gaming, and just being awesome all around. It wasn't really a rationalization (old comp was dead), but rather I knew it was going to be used strenuously.
For those wanting to upgrade...you should never have to see a load screen in Adobe
09-10-2008, 03:34 PM   #55
Moderator PEG Judges
Kerrowdown's Avatar
You mean there is something else apart from raw
09-12-2008, 10:42 AM   #56
TiJean's Avatar
As with just about everything else it seems, my answer is a resounding it depends. Rarely I shoot JPG, sometimes I shoot RAW, I generally don't shoot JPG +RAW anymore because it was so repetitive and space hungry. Sometimes I shoot as a professional, sometimes I shoot as an amateur, and occasionally I shoot as an amateur and use the images professionally (usually in my capacity as a graphic designer).
Personally, I find RAW files faster and easier to process than JPG files. Even if I convert from RAW to TIFF, I still get more information (usually in reality, always in theory) then if I were using native JPG.
These are are just my personal preferences. RAW works into my workflow very well, though now perfectly, and with storage as cheap as it has become, the size is a small issue for me.
09-12-2008, 12:52 PM   #57
semi-pro. always always always RAW. and then i view / manage the images in aperture on a mac. from there, i can do anything to the image i want and i can still retain the digital negative. sometimes i bring the final image into photoshop to do minor adjustments to a specific area.
also been in the graphic arts business for 30 years. when you pre flight a file for printing, flightcheck will always flag a jpg. printers / rip software hate jpgs. they're only good for web work. shooting in RAW and adjusting in aperture (or lightroom) will give you the best of both worlds.
09-12-2008, 04:56 PM   #58
monochrome's Avatar
RAW vs. JPEG
I picked Amature JPEG for the following reasons.
I consiedr myself an amature. I shoot simply for my own pleasure (excluding technical reporting) and I shoot JPEG simply because I am satisfied with the results I get, and my ability to manipulate the images afterwards, even with the occasional exposure issue to get excellent results.
I woudl be interested to know how many JPEG shooters began in film, and had to know the ins and outs of High vs Low ISO films, contrast color temperature etc. I'm willing to bet more film shooters shoot JPEG because it is easier for them to understand how to select thier settings. Film was far less forgiving
Lowell: I've shot SLR on film off and on since 1977; some flurries of attempts at art when I had a new body (KX, MESuper), then just snapshots for long periods. I even went through the 90's where all I did was SureShot film P&S.
I did get an OLY E20N late in 2005 and it was a fine DSLR. Shot in JPEG and TIFF on that (512Mb CF card max!!).
On the K10D since March I have shot exclusively RAW, but due to PP software limitations I have to convert to JPEG either in PPB or PPL. I am intentionally trying to manage the ISO settings to accomplish film-like results.
One thing I am trying is to shoot a scene with the KX and the K10D at the same ISO setting to see what happens, usually with a 35 or a 50 since I have manual and auto versions of similar / identical lens designs.
I like having the RAW files on DVD if I ever really get to be a decent post processor.
09-12-2008, 07:16 PM   #59
jacksonpritt's Avatar
Even though part of my job involves me taking photos for a website (product shots, models wearing clothing, etc), and I sometimes shoot in JPEG, I chose Amateur, RAW.
The bulk of my photography is amateur, and the bulk of my shots are RAW.
Good poll!
09-12-2008, 07:27 PM   #60
QuoteOriginally posted by thePiRaTE!! Quote
Well, I think it's easy to forget just how huge RAW files are sometimes, especially for amateurs.
I edit my photos on a Powerbook with an 80GB HD at work, and with my average RAW file at 10-14mb and regular photo-shoots of 100-300 pictures, I'm constantly running up against memory limitations.
I suppose the real solution is just to be more diligent about throwing out shots I know I won't end up using, but it's darned annoying.
camera, dslr, photography
First Paying Job? murviper Photographic Technique 16 07-13-2010 02:28 PM
Rebuilding the 35 MM Format FA* line to the DA* APS-C Format Adrian Owerko Pentax SLR Lens Discussion 14 01-20-2010 11:04 AM
trying to find a job?! catsman50 Photographic Industry and Professionals 7 11-28-2009 03:20 PM
500 Job graphicgr8s General Talk 41 06-26-2009 07:08 PM
All times are GMT -7. The time now is 11:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
