Closed Thread
05-18-2018, 10:20 AM - 1 Like   #16
Cambo's Avatar
They should redo that ENTIRE review, AND issue an apology...
Disgraceful. Multiple errors in a 'scientific' test? That place has been reduced to the TMZ/Fox News of the photographic world. Fake photographic news.
Disgusting.
Cheers,
Cameron
05-19-2018, 02:23 AM - 1 Like   #17
QuoteOriginally posted by Cambo Quote
Disgusting.
You might want to add that it is the third article in a row that they screwed up big time (the original K-1 review also had errors, image file swapping, denials proven wrong afterwards and the pixelshift article had to be redone).
05-19-2018, 06:01 AM   #18
retired sw engineer
reh321's Avatar
A test isn't "scientific" if you change more than one variable at a time, because then you aren't certain what you tested.
Should use same lens on different cameras if you are testing cameras.
05-19-2018, 07:24 AM   #19
monochrome's Avatar
QuoteOriginally posted by reh321 Quote
Shouild actually use the same copy of the same lens. Of course, that isn’t possible.
Then they should use precisely the same lighting, position and exposure for each shot by each camera, right down to measured ISO rather than claimed ISO. The camera settings should start at an identical position, and each should be changed according to a set pattern. The processing should use precisely the same, neutral presets for every camera, without camera profiles to produce images for neutral viewing comparison. None of which is possible.
Therefore, by scientific convention, these tests can easily be manipulated with malice aforethought, can be bungled by ignorance or carelessness, are subject to manufacturer gaming and both standards bias and confirmation bias.
Thus conclusions must be subjective and must be clearly labeled subjective.
Really, though, the problem isn’t the testing protocol. The problem is the hubris to claim the tests are scientific when in fact they never can be so.
But - Ph.D. !!!
05-19-2018, 07:32 AM   #20
normhead's Avatar
The simple fact is, their tests and commentary aren't rigorous. Their testers are unreliable, and their commentary is biased. And they are unfamiliar with the every day things Pentax users do tot get the best out of their cameras.
For Pentax users, the site is pretty much useless.
05-19-2018, 08:04 AM   #21
Man With A Camera
Racer X 69's Avatar
We don't need two threads discussing the same thing.
Closed Thread
camera, confession, dpr, dslr, files, ii, image, k-1, k-1 ii, lens, photography, review, review message
Suggestion I messed up in the review section Le Chuck Site Suggestions and Help 4 07-01-2017 04:24 AM
My pending 200mm range lens comparison, LBA confession, and questions YeOldePentaxian Pentax SLR Lens Discussion 6 07-15-2016 06:09 PM
Sony NEX-5N Review now up at DPR jogiba Non-Pentax Cameras: Canon, Nikon, etc. 13 10-16-2011 10:29 PM
K-7 froze in video mode, now messed up dedmozaj Troubleshooting and Beginner Help 4 05-18-2011 04:26 PM
WR100mm review messed up mtroute Site Suggestions and Help 5 03-14-2011 03:24 PM
All times are GMT -7. The time now is 01:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
