09-09-2008, 05:43 PM   #1
jfsavage's Avatar
Debug menu for *ist DS v2.01+
There is information available on how to get into the debug menu on the *ist DS to adjust the focus, but the instructions do not seem to work for v2.01 of the firmware. Does anyone know of a way of doing this?
Jonathan
09-09-2008, 08:05 PM   #2
Powermarc's Avatar
I just got the key sequence misplaced somewhere, i will get to you on that tomorrow when i will find them...
09-09-2008, 09:06 PM - 2 Likes   #3
frank's Avatar
Here you go:
1. Power OFF
While pressing [AE-L]+[INFO], turn the camera on.
Firmware is desplayed on LCD.
Press [MENU]->[MENU]->[INFO] within 5 seconds.
You can see DEBUG mode screen.
Press [MENU] to bring up the menu
By pressing [Right key],Make [DEBUG MODE DIS] to [DEBUG MODE EN].
Then, Press [OK].
2. Press [MENU], then get to the Setup menu.
By pressing [Up key], select AF TEST.
By pressing [Right key], go into AF TEST menu.
By pressing [Down key], select FOCUS CORR.
now you can adjust shift amount by pressing [right key] or [left key].
(*Don't touch AF Area Test.)
Add value for back focusing, minus for front focusing
after changing the value, Press [OK] to save.
3. Test your camera that Focus is corrected.
(repeat step 2. till you are satisfied w/ the result.)
RETURN TO NORMAL MODE:
4. Power OFF
By pressing [Right key],Make [DEBUG MODE EN] to [DEBUG MODE DIS].
Then, Press [OK].
It shoud work
I guess I've been getting in and out of debug mode so frequently, I can change an AF value in a matter of seconds (on Ds, DL, K100D)
09-10-2008, 09:13 AM   #4
jfsavage's Avatar
Battery issue?
I played around with this last night to no avail. I tried again this morning with fresh batteries, and get straight into debug mode without a problem.
Thanks,
Jonathan
BTW, does anyone have a starting point for IR focus adjustment?
09-10-2008, 07:03 PM   #5
frank's Avatar
QuoteOriginally posted by jfsavage Quote
Thanks,
Jonathan
Glad to know that it works now
AF adjustment for IR depends on the camera, the lens, and the IR filter installed. There is no fixed rule for it. The best way to do AF adjustment is to mount the lens on your IR converted camera, do some wide open test shots under bright light condition when focusing on something very contrasty (like road tags) and see if the sharpness is good enough. Normally you'd facing some back focusing problem w/ IR, so you'd add some value when doing AF adjustment.
09-11-2008, 05:00 AM   #6
Powermarc's Avatar
Thanks frank, you were faster! :-)
12-13-2012, 01:52 PM   #7
Nick Siebers's Avatar
Resurrecting the thread to say thanks! My DS is spot on now with the debug above.
*ist, camera, debug, debug menu, ds, dslr, menu, photography
Samsung GX20 debug menu - where is AF TEST? pa79 Pentax DSLR Discussion 1 07-22-2010 03:20 PM
Debug menu access for the K100DS? Nachodog Pentax DSLR Discussion 3 04-14-2010 02:27 PM
Anyone know if 'debug' menu is available for Nikon cameras? jsherman999 Canon, Nikon, Sony, and Other Camera Brands 2 12-18-2009 07:07 PM
K10d-debug menu-IR possible? Bokeh Pentax DSLR Discussion 6 05-17-2008 05:54 PM
K100D Super Debug menu joelw135 Pentax DSLR Discussion 9 10-18-2007 04:23 AM
All times are GMT -7. The time now is 03:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
