02-23-2007, 06:40 PM   #1
slip's Avatar
K10 pop up flash as a slave?
My sigma DG500 super is in for service and I was wondering if there would be a way to get my K10 pop up flash to be triggered from my wife's K100?
just wanted to do some experementing..
cheers
randy
02-23-2007, 06:44 PM   #2
Alvin's Avatar
Randy,
I doubt it. Venturing to other brand, a D50 won't trigger a D80's on board flash (we tried everything, short of breaking the flash off).
02-23-2007, 09:24 PM   #3
SpecialK's Avatar
QuoteOriginally posted by slipchuck Quote
cheers
randy
Hi Randy:
Check the "using an external flash" (or equivalent) section of the manual. The K100D manual has a "yes/no" list of flash features, and the answer is...nope, onboard can't be a slave...
02-23-2007, 09:26 PM   #4
slip's Avatar
thanks Alvin
thanks special K
I didn't think it would be possible... thought I would give it a shot
thanks again
cheers
randy
02-24-2007, 02:14 PM   #5
gorfmai's Avatar
cheers
randy
Just get a small el cheapo single pin flash, slap a slave under it, and stick it on the K10, go to a photo show by you and you should be able to find those pieces used for less that $20 or so...
02-24-2007, 04:50 PM   #6
slip's Avatar
QuoteOriginally posted by gorfmai Quote
thanks
I have an old flash, but the slave that goes on the bottom of a flash is a bit to much for me up here in canada.... $80 dollars.
I will likely get one someday though...
thanks again for the idea
randy
camera, dslr, flash, k10, photography, pop, pop up flash
optical slave flash help Hiroshi Troubleshooting and Beginner Help 4 03-26-2011 11:07 AM
k10 pop up flash slip Flashes, Lighting, and Studio 2 02-01-2011 01:23 PM
k5 pop-up flash hook (that holds the flash down) broken... Thesorus Troubleshooting and Beginner Help 4 01-06-2011 08:34 PM
k-7 + 3 sec delay = no flash slave. Anyone know why? Nass Pentax DSLR Discussion 5 03-16-2010 09:57 AM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
All times are GMT -7. The time now is 04:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
