The K-x does not use the D-Li109, only 4xAA batteries. The K-S2 cannot use AA batteries. The only bodies to use either were the K-r, K-30, K-50, and K-500. (Not counting external grips.)
Originally posted by grahame I guess the thing bothers me the most is: since the D-LI109 battery has 7.4V (8.4v actual measured), why would Pentax suggest using 4XAA batteries.
You're kind of putting the cart before the horse here. Up to the K-x, all the low-end Pentax bodies were built around 4xAA batteries. Supporting 4xAA batteries was just a legacy feature from teh K-r on. Since Pentax supported AA batteries inside the body far longer than any other DSLR maker, and they stopped after the K-50, it's kind of a moot point.
Five volts is fairly standard operating voltage for digital electronics. Four alkaline cells in series is 4x1.5 = 6 volts, which the camera regulates down to 5. Four NiMH cells are generally enough at 4.8 volts, although I also remember the issues with rechargeables when the K-x first came out (Eneloops seemed to work, even with FW 1.00). As Not A Number said, alkaline batteries start with a higher cell voltage, but this drops fairly quickly; NiMH has a lower cell voltage, but it holds that voltage much longer, until the cell is exhausted. (This is known as the battery's "discharge curve".)
Then Lithium ion batteries came out, but their chemistry gives a nominal cell voltage of around 3.7 volts instead of 1.2 or 1.5 volts. One cell is not enough, so each battery has two cells in series, giving 7.4 volts, and the camera regulates it back down to 5 volts. There's nothing special about 7.4 volts - if you had 6xAA NiMH batteries, they might still be wired to give 4.8 volts, with two of the cells in parallel to provide more amps.
