Originally posted by dubyam Does the new PLM lens work with the K7 & KS2? . . .
K S 2 yes, K 7 no
*This lens [ HD Pentax-DA 55-300mm F4.5-6.3 PLM WR RE ] uses an electric focus-by-wire system and will not focus (even manually) on cameras older than the Pentax K100D super (2006).
**Because the aperture is controlled electronically, this lens can only stop down when used with compatible cameras. The Pentax K-50, K-S1,
K-S2, K-3, K-3 II, and K-1
are supported via a camera firmware update; the Pentax K-70, Pentax KP and all 2017 or newer bodies will work out of the box. The aperture diaphragm will always remain wide-open on unsupported bodies.
In an nutshell, this lens fully compatible with recent DSLRs but shouldn't be used on older bodies or film cameras.
Read more at:
HD Pentax-DA 55-300mm F4.5-6.3 PLM WR RE Review - Specifications | PentaxForums.com Reviews
The upside to the move to KAF4 is that the lens now has fewer moving parts, and that aperture control makes less noise. If you don't have a physical aperture lever, it can't get jammed. The downside is that this lens can only be used by cameras that recognize the new KAF4 mount. As of early 2017, the list includes the K-1, K-3, K-3 II,
K-S2, K-S1, K-50, K-70, and KP. All future bodies should also be KAF4-compatible. All of the aforementioned cameras save the K-70 and KP first need a firmware update to support this lens.
Read more at:
HD Pentax-DA 55-300mm F4.5-6.3 PLM WR RE Review - Construction and Handling | PentaxForums.com Reviews
__________________________________
Pentax Lens Compatibility Chart
Copyright 2006-2016 Mosphotos.com. All rights reserved.
Pentax bayonet lenses labeled "SMC Pentax" are referred to as "K" lenses in the table below. Other Pentax bayonet lenses have the lens designation as a part of their name as in "SMC Pentax-FA."
Note that "star" lenses work like their "non-star" counterparts: DA* lenses work like DA lenses, FA* like FA, F* like F, A* like A, and M* like M.
Exceptions:
FA and F "soft" lenses behave like M lenses in terms of metering.
The Pentax Camera Lens Compatibility Chart
________________________________________________________________
Pentax K-Mount Lens Series Explained: The differences between various Pentax lens series
In a nutshell
There are several series of Pentax K-mount lenses; the ones currently being produced include the DA (digital), DA L (cheap digital kit), D FA (full-frame, digital optimized), and FA (full-frame) series. While all Pentax K-mount lenses ever produced are compatible with all current Pentax DSLRs (in some cases with restrictions in that not all exposure modes of the camera are supported by old lenses), there are significant differences between each lens series and each has different features. Furthermore some of the newer lenses do not work with older cameras. We'll be exploring the differences between the various K-mount series lenses in this article. Read more about specific K-mount lens/camera compatibility here.
The DLSR designation below encompasses the mirror-less K-01.
Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
