Show Printable Version 12 Likes Search this Thread
06-19-2018, 04:51 PM   #1
Paul Charlier's Avatar
Lens update
Hi, I currently have a Tamron 18-250 which I use on my K7 and K-S2 bodies. I am thinking of upgrading to the Pentax 18-270 lens. Just wondering if the performance increase would justify the investment?
06-19-2018, 05:05 PM - 1 Like   #2
Otis Memorial Pentaxian
clackers's Avatar
With all due respect, Paul, despite the convenience all those kinds of superzooms are generally the least performing in all brands in terms of image quality, and swapping one from the other may really disappoint you after you spend the money!
06-19-2018, 05:20 PM   #3
Digitiser of Film
BigMackCam's Avatar
Hi Paul, and welcome
I'd have to agree with @clackers on this. So-called "super-zoom" lenses have their uses, but they're always a huge series of compromises optically, and don't bring out the best in decent cameras. If I were you, I'd keep the Tamron 18-250 for those occasions where you really need that focal length versatility over every other aspect, and - considering the capabilities of your K-7 and K-S2 bodies - think about something better optically (if more limited in focal length range)
If you absolutely must stick with a super-zoom, the Sigma 18-300 is very good within that class of lenses (and much better than the Pentax 18-270), but still very compromised
06-19-2018, 05:25 PM - 4 Likes   #4
QuoteOriginally posted by Paul Charlier Quote
Hi, I currently have a Tamron 18-250 which I use on my K7 and K-S2 bodies. I am thinking of upgrading to the Pentax 18-270 lense. Just wondering if the performance increase would justify the investment?
A good alternative would be the DA 18-135mm or the DA 16-85mm plus the 55-300mm F4.5-6.3 PLM. That would give you a bump up not only in terms of image quality, but also focusing speed, across the board.
06-19-2018, 06:07 PM - 3 Likes   #5
SSGGeezer's Avatar
Bingo! Anything shorter with the 55-300 PLM is a great combo. I even got a picture of a Unicorn with my 55-300 PLM!
PENTAX KP  Photo
06-19-2018, 06:24 PM   #6
Superzooms have their place and yours is a good one for that range. You won’t gain much going to the 18-270. The zooms mentioned by others are better and you can also supplement the superzoom with primes. I would start with the DA 15 for a reasonable and compact ultra wide.
06-19-2018, 06:27 PM - 1 Like   #7
Paul the Sunman's Avatar
It's called an Interchangeable Lens Camera (ILC) for a reason. You can change the lens. The 16-85 + 55-300 (any version) option would be a huge step up for you.
06-19-2018, 07:29 PM   #8
I will second that.
Notwithstanding the comments of others re the optical quality of lenses of this class, my experience with the Sigma 18-300 suggests that at the long end it is one of the sharpest lenses I have.
It does tend to be slower to focus than my other lenses, but this isn't much of an issue expect for BIF and such like.
Cheers,
Terry
06-19-2018, 07:31 PM   #9
Does the new PLM lens work with the K7 & KS2?
Aside from that, I've had excellent service out of a shorter zoom (walk-around lens) and a longer zoom for real reach when needed.
06-19-2018, 07:34 PM   #10
SSGGeezer's Avatar
KS2 should be no issue. The K-7 is a no unless you want to shoot wide open all the time.
06-19-2018, 07:35 PM - 1 Like   #11
onlineflyer's Avatar
Another alternative is to pick up a used DA 20-40mm F2.8-4 Limited in the marketplace and a new 55-300mm F4.5-6.3 PLM.
06-19-2018, 07:57 PM   #12
jimr-pdx's Avatar
To answer the original question, I have not heard anyone speak of better performance from the 18-270 model. Booth Tamron/DA and Sigma hit a relative sweet spot with the 18-250.
I do agree however that a two- or three-lens set will result in better overall results.
06-19-2018, 07:57 PM   #13
Thanks, yes I was thinking it wouldn't be worth it really, I mainly use it for overseas travel as my FDA 150-450 lense is rater heavy. I also have a D FA 100 macro and a DA 10-17 fisheye. As Adam suggested my other option was to get a DA 18-135 for overseas travel, as they are quite compact.
06-19-2018, 09:51 PM   #14
tvdtvdtvd's Avatar
QuoteOriginally posted by Paul the Sunman Quote
This^^^^^^ All day long.
It's hard to imagine the desire for a do everything super zoom on an ILC. Why not just buy a really good fixed lens camera?
As much as I prefer primes over zooms, I will concede the convenience of a zoom does have its allure and can understand
how some shooters are willing to live with their shortcomings for access to variable FL on the fly. But if you're going to go
to the extreme of covering almost the entire range with just one lens, why bother with an ILC?
06-20-2018, 12:36 AM - 1 Like   #15
hcc
hcc's Avatar
I had a DA18-250mm that I replaced by a DA18-270mm. I am a prime lens shooter mostly, but I value highly the convenience of the DA18-2XX mm. I have also a DA18-135mm, mostly because of its WR feature.
The DA18-270mm is, like the DA18-250mm, the perfect all-around lens in my opinion. It is small, compact, relatively light weight and very versatile. I loved my DA18-250mm and I love my DA18-270mm. I considered alternatives like the Sigma 18-250mm and Sigma 18-300mm. In each case, the weight and size was an issue for me. I often bushwalk with my camera and lens, and I want something light to carry. In addiition, the Sigma 18-300mm was pricier than the DA18-270mm at the time of my purchase.
If I compare side-by-side the DA18-250mm and DA18-270mm, I am very impressed by the AF of the DA18-270mm, its speed, reasonable accuracy and it is almost silent. IMHO, the AF is a major improvement over the DA18-250mm.
Similarly I have the DA18-135mm. Both my wife and I use love the DA18-135mm. But the DA18-270mm is more versatile in my opinion.
In summary, I would rate this lens as an excellent all-around zoom lens. My main criticism is the lack of WR. Off course the IQ of DA18-270mm is well below that of most prime lenses. But that is not the point because one should compare apples and apples, and oranges and oranges.
Hope that the comment will help.
18-250, 18-270, articles, camera, dslr, lense, pentax da, photography, terms, tips
Update of DCU 5 cannot find the old version to update on my K-3ii Elizabeth Troubleshooting and Beginner Help 2 01-27-2018 01:11 PM
K70 firmware update 1.1.0,DCU update 5.6.1 OoKU Pentax News and Rumors 4 09-07-2016 02:19 AM
lense hood help (50-200mm lense for k-30) obsidianjeff Troubleshooting and Beginner Help 5 05-06-2014 06:46 PM
Universal lense wide lense: Tamron 17-50mm F/2.8, DA 16-45mm F4, DA 17-70mm ? Vejas Pentax SLR Lens Discussion 12 02-11-2014 12:04 PM
Noob Question Difference Between a Lense That Does Macro & A True Macro Lense Christopher M.W.T Troubleshooting and Beginner Help 16 07-19-2009 12:20 AM
All times are GMT -7. The time now is 11:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
