Unless you're always planning to shoot wide open (or stopped down all the way) a bellows would especially suck on the aperture ringless dfa100mm WR. You could probably work out a way to manually stop down the aperture to what you want, but ehh, if a bellows is part of the plan you'd be better off picking up a wider focal length lens with an aperture ring.
Originally posted by BROO The DCR-250 pairs wonderfully with the dfa100mm, it gives you 0.8x to 2x magnification depending on what focusing distance the lens is set to. Far more useful than bellows or tubes on a 100mm macro (in my opinion). Example:
Also see Pascal's photostream (forum member Doundounba), which has many fabulous examples using the dfa100mm and a raynox, sometimes with the 1.4x HD TC:
https://www.flickr.com/photos/doundounba/
