Originally posted by wmsnyder65 Anyone else experience this issue?
I did loose the data because of this. When ever I get this error, I had to format(using Camera) and also power-cycle the camera. If I did not power-cycle, I used to loose the pictures taken in between "time of formatting" to "time of power-cycle". I was able to reproduce part of this problem. I was getting this error consistently, after I use the card on Ubuntu 16.04.
Steps: (I repeated this 5-4 times, and result was loss of data, every time )
1) Delete the files in SD card using Ubuntu machine
2) Load the card in to K1
3) K1 shows "card not formatted..."
4) Format the card using K1
5) Take pictures (without turning off K1)
6) Check the pictures in K1 using preview (they are there)
7) Load the card in to Ubuntu, files
are missing
Root cause for format error?
I do not know what started this error, but it went away once I formatted the card using Win7. I use the card across OS( Win7, Win10 and Ubuntu). May be one of the OS could have corrupted the card.
Symptoms
It was 64GB card and was using EXFAT. Ubuntu was able to identify the filesystem correctly.
