a new sensor will be good news,
- higher dynamic range, at least by 1+ 2+ preffered,
- cmos or ccd, as long as the readout is fast enough for high pixel count,
without, getting readout noise in channels, banding,
foveon, style be good too, but think, cmos would be the easiest to implement,
the DR is another story
- delivery, a new sensor, without having the capacity to deliver, is not going to be beneficial, on the other hands not beeing dependant on a sony delivery schedule,
and on the same token, having to compete with nikon,sony, with the same sensor on the market , will make a differentiation,
- customers going to be eager to compare it to the existing sensors, as such does need to perform, but if there is enough confidence, there should be a preliminary review with tests, press releases, protoypes as soon as possible,
since for existing photographers, it's lot easier to choose the save path
- 1.3x and full frame ASAP
other important things
- lens availability, post it !! even if it's tentative
- push sigma,tokina for lenses,... availability and choise is very important
- annouce assurance in the Hoya merger, what pentax roadmap and leverage is going to be !!
- announce new prototypes, asap, since the pending merger, you don't want to have photographers sitting on the fence for another year, hopping for the best,
take that equation out, by blasting news to the front,
don't think it's going to be as bad as the minolta/sony merger, with lack of products and info, but no news in this case is the worst news !!
cmos be easier on the power, but blooming, etc, still a problem,
and don't forget, support circuit, RF shielding, (diecast body), for the 645d, i'd even build-in some cooling, .... noise per deg temp rise,.... could be lower or more controlled,
last not least, fps should be possible to be in the fps 5+ range, even with full size sensor, mech, or mirror limitation aside,
just my 2 bins, Robert
Originally posted by benjikan Another little survey...
Should Pentax perhaps in collaboration with another manufacture develop their own sensors an if so which type would be attractive to you?
