Originally posted by kseld ....Two, actually. On one camera, in the Rec. Mode of the menu, the AF Mode is gray, and the down button skips over it so I can't change the setting.
Also, on the other camera, in the Rec. Mode of the menu, the setting for AE Metering is white, whereas it's green on the other camera. I am unable to change the setting to multi-segment, which I prefer....
Some menu settings are only adjustable in certain shooting modes. Typically, the auto or semi-auto modes will disable some menu settings. For example, on my k100d if the mode dial is in "SCN", then the autofocus in the record menu is greyed out and set to Af.S. If I switch to "P" mode on the dial, AF is no longer greyed out and I can change the autofocus to Af.S or Af.C.
The lens you have mounted may also be an issue, with older 'legacy' lenses not having all options available.
