Originally posted by kseld Is there a setting that was changed that I need to reset? I can't find it.
Hi kseld,
If you want to set the basic functions, read the manual in English on Page 220 or, follow these steps:
Resetting Rec. Mode/Playback/Set-up Menu
Settings in [A Rec. Mode] menu, [Q Playback] menu and [R Set-up]
menu can be reset to default settings.
However, Date Adjust, Language/ , Video Out, Text Size, and the
World Time city settings are not reset.
1 Select [Reset] in the [R Set-up] menu.
2 Press the four-way controller (5).
The [Reset] screen appears.
3 Use the four-way controller
(23) to select [Reset].
4 Press the 4 button.
The settings are reset and the camera is ready to take or play back
images.
Kind regards.
