Originally posted by Barry Pearson If Pentax launched a K-mount mirrorless camera with an eye-level viewfinder, I might buy it, perhaps to have alongside an SLR instead of a replacement for it. (But who knows?) If it had a shorter registration for some reason, I would need a fully-operational adapter for modern K-mount lens. I think it would be a serious mistake for Ricoh/Pentax to expect people with a large investment in their recent lenses to replace them all with shorter-registration lenses.
If there would be a Pentax MILC before the end of the decade, it most likely will use a different mount with some sort of adapter for K-mount. A K-02 FF in KAF2 is highly unlikely.
I would expect that legacy pawl-drive AF in an adapter is asking a little much and will substantially increase the size and weight. Likewise, having mechanical aperture coupling would be nice, but with a cost in size and weight. The Sony solution would be a good guide as to what to expect. I know that sounds dumb and cruel and counter intuitive, but there is historic precedent. In a box on my lens shelf are three genuine Pentax Mount Adapter K. Despite having a significant installed base of SMC/S-M-C Takumars out there and the theoretical means to engineer full auto-aperture legacy support,* Asahi chose to launch the new K-mount with only the slimmest of backward compatibility.
I suspect that history will repeat itself unless the dSLR line is axed altogether. AF for in-lens-motor designs only and body-controlled aperture is what I would expect.
* The K- mount coupling implementation at launch was arguably the most advanced mount of the time. Body size and weight constraints would have made legacy aperture actuation and/or aperture ring coupling very difficult to implement. Given that body-controlled aperture was likely also in the works, continued limited support was a wise compromise.
