Show Printable Version 6 Likes Search this Thread
07-28-2018, 01:16 PM   #16
c.perkins's Avatar
QuoteOriginally posted by Aslyfox Quote
according to this, it won't work cover the FF sensor:
The Pentax DA* 300mm F4.0 lens was introduced in 2008. It is designed for digital cameras, and as such cannot be used on film cameras as it does not cover the full-frame image circle.
Read more at: Pentax-DA* 300mm F4 Review - Design and Handling | PentaxForums.com Reviews
but
Designed for APS-C but officially full-frame compatible per Ricoh. The Pentax K-1 includes full-frame correction profiles for this lens.
Read more at: SMC Pentax-DA* 300mm F4 ED [IF] SDM Reviews - DA Prime Lenses - Pentax Lens Reviews & Lens Database
I have an issue with these two articles, especially the first one cause the second article I am not exactly sure what they are describing.
My copy of the DA*300 covers the image circle of my 35mm film bodies and of coarse the K1.
Maybe I am misunderstanding.
I would hate people being swayed away from the DA*300 for use on a FF body because of a statement that may not be totally true.
Clarence
07-28-2018, 02:07 PM   #17
Seeker of Knowledge
aslyfox's Avatar
to be clear, I just found sources
which appear to conflict
I don't own a K 1
but I do own K 3 and K 3 II and the SMC Pentax-DA* 300mm F4 ED [IF] SDM
perhaps someone that does own a K 1 or K 1 II and the SMC Pentax-DA* 300mm F4 ED [IF] SDM could bring the inconsistency to Adam's attention and
see if we can get it cleaned up
07-28-2018, 02:17 PM   #18
c.perkins's Avatar
I don't own a K 1
It's okay Allen
Do not take it personally cause I quoted you
I know that you are just posting links/sources.
I did look for an author of those posts but could not find.
So getting with Adam is the next probable step.
Clarence
Added;
Question posted in site suggestions/help.
07-28-2018, 02:52 PM   #19
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by c.perkins Quote
It's okay Allen
Clarence
no problem, just wanted to make clear that I had no personal experience with the K 1 or K 1 II
I would like the inconsistency cleared up too
07-28-2018, 02:56 PM   #20
c.perkins's Avatar
Allen;
I just posted on site suggestions/help concerning this matter.
Clarence
07-28-2018, 03:22 PM   #21
monochrome's Avatar
^^ I didn’t read the articles, but FYI Pentax has certified the DA*300/4 as fully FF compatible.
07-28-2018, 04:33 PM   #22
c.perkins's Avatar
I think certain people know this.
What I do not like is conflicting information especially on a Pentax forum.
Guess what happens when you Google "Pentax DA*300"
Brings up PF individual reviews and if you click the "In Depth Review" Viola (misinformation).
Clarence
07-28-2018, 04:48 PM   #23
You don’t need to do it all at once. Get a K-1 at a discount. Get a lens; maybe sell a lens. Get the grip. Get a nice monopod. You’re set for XMAS and birthdays for a while.
K-1, *50/1.4, *70~200 and 28~105 is one heck of a nice bag. 24~70 is cake with your ice cream.
Yes... I am thinking a K1 II, but will have to wait for my bonus at work... Then it might happen, I will stick with the 28-105, it will more than serve my needs all the reviews are pretty glowing. I knew buying the second FF * lens was a bad idea.
Can’t forget my crop bag... I pretty much have everything covered.
---------- Post added 07-28-18 at 04:53 PM ----------
Didn’t mean to cause such a stir on the DA 300 on the K1 / K1 II... Just wanted to make sure it would perform well.
Thanks all.
07-28-2018, 04:59 PM   #24
c.perkins's Avatar
QuoteOriginally posted by gm4life Quote
Thanks all.
You did not cause a stir.
We wanted to make sure that you and others new to the K1 understood that the DA*300 works perfectly with it.
Clarence
07-28-2018, 05:04 PM - 1 Like   #25
Sandy Hancock's Avatar
The 28-105 and a fast fifty is a potent combination - to the point where I am considering whether or not to keep my DFA24-70.
The DA*300 is wonderful on the K-1, and completely full frame compatible.
Just buy the body. You know you want to
07-28-2018, 05:04 PM   #26
QuoteOriginally posted by mikesbike Quote
There are certainly some advantages to FF when it comes to certain lenses. But, funny to me that you bring it up regarding a 50mm lens. All the years I shot 35mm film, after the first 6 years of mostly having no WA and just one 135mm tele, so that most of my activity was from the 50mm FOV, when acquiring other lenses I eventually came to using the 50mm least of all! For my "normal" lens I much preferred my FA 43mm Limited! Secondly, if I wished a little more WA latitude. it would be my FA 35mm f/2.
The 50mm lenses I have gained more usage after I went into APS-C digital! If I should decide to get a FF DSLR, it would be to again use the above 2 lenses in their FF FOV, along with a few others. I would get it with the D-FA 28-105 for all-around use and having WR, and I might then even get the FA 31mm Limited as well. I would tend to keep the lenses on the moderate to light side so the whole ensemble would be less cumbersome. My largest and heaviest would be my Tokina ATX 28-70mm f/2.6-2.8 Pro II.
I too love the 50mm range on crop for portraits. Heck I have gone out only with a 50 on a crop, but like the focal length on FF from my film days.
07-28-2018, 05:06 PM   #27
Craig66's Avatar
Have the DA*300mm works fine on the K1 in FF. Great combo.
07-28-2018, 05:07 PM   #28
Thanks Sandy. I keep hearing that on the 24-70 for a smidge 2200, 2300 bucks a K1 II with the wonderful all around 28-105 ticks a lot of the right boxes. Thanks for confirming the DA 300’s awesome performance in FF.
Hmmm... This place is like a bad addiction. You all were supposed to talk me out of FF!
07-28-2018, 05:12 PM - 2 Likes   #29
c.perkins's Avatar
You know dang well that that is not going to happen around here
Clarence
07-29-2018, 04:20 PM   #30
Clarence
Good point. After all this discussion the K1 II is next on my “hit” list.
allen, camera, crop, dfa, drive, dslr, ii, k-1, k1, lens, matter, photography, raid, site, space
Some questions about buying sony full frame + adapters + pentax full frame lens jhlxxx Pentax Full Frame 7 06-14-2017 05:13 PM
K-1 So What Is Full Frame Going To Provide Over A Crop Frame DSLR MRCDH Pentax Full Frame 312 03-22-2016 01:21 PM
Pentax Full-Frame, DFA* 70-200mm, DFA 150-450mm Announced Adam Pentax News and Rumors 544 03-14-2015 05:29 AM
From Full-Frame Sony... to Pentax... to Full-Frame Canon Mr_Canuck Canon, Nikon, Sony, and Other Camera Brands 42 01-21-2014 12:50 AM
Full frame or no full frame.... Deedee Pentax K-3 & K-3 II 14 10-08-2013 05:39 AM
All times are GMT -7. The time now is 06:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
