08-28-2018, 07:01 PM   #166
There are also systems that mount a clip to a backpack strap to redistribute the weight. The clip goes on the bottom and usually acts as a swiss arca type quick release plate also.
Oh, interesting!
---------- Post added 08-28-18 at 07:04 PM ----------
QuoteOriginally posted by TER-OR Quote
Yes, the heavier the camera the more you'll want to get the weight off your chest!
This year on the prairies I'm carrying the K-3 with FA100mm macro and ring flash on one strap, and my K5 with DA300 on the second strap. This is the harness: BlackRapid | Double Breathe
My K-5 with a 50mm f2 is pretty light, so I suppose that's why I have no problem with using a neck strap. It would be a pain to have my 75-300mm on it, though.
That's quite the harness! Probably makes the cameras feel like feathers.
08-29-2018, 02:34 AM - 1 Like   #167
pxt
Interesting strap is from Peak Design:
Clutch Camera Hand Strap | Peak Design
To be honest I don't use it. I see only video, so I can't say that it I can recommened, but is maybe other option to consider for you.
08-29-2018, 06:53 AM - 1 Like   #168
TER-OR's Avatar
QuoteOriginally posted by Ropuchy Quote
Oh, interesting!
I wouldn't go that far!
It does distribute the weight well, though, and keeps both at the ready.
08-29-2018, 10:52 AM - 1 Like   #169
pxt
Neck strap it can be use as stabilistation:
08-29-2018, 12:18 PM   #170
QuoteOriginally posted by pxt Quote
Ah ok, thanks!
---------- Post added 08-29-18 at 12:19 PM ----------
Yeah, I might have been exaggerating a little bit
I'm sure having both cameras at the ready is very useful!
---------- Post added 08-29-18 at 12:21 PM ----------
I've used my neck strap in that way before. It works alright.
I'm sure the same can be done with other types of straps and harnesses, though.
08-29-2018, 01:53 PM - 2 Likes   #171
rogerstg's Avatar
Since the 1980s, I've been using a simple sling set up instead of "around the neck" orientation. As a casual amateur, I found it much more convenient to have the camera resting at/in my right hand, near my hip. When moving about, it is less obtrusive than a tele lens projecting from my chest, and allows me to shift it to the front or behind as needed. Back then, I simply fastened both ends of a neck strap to one lug. It worked pretty well. When not using the sling strap, I use a simple wrist strap. It allows me to carry the camera in a relaxed manner, with added safety if it is somehow knocked free. It hasn't happened in 30+ years, but serves as cheap insurance.
I've recently "upgraded" to a purpose built sling strap and wrist strap. I'm not yet sure how much of an upgrade it is, aside from better security, ease of adjustment and slightly better fit. I use the Peak Design Slide Lite, as a sling strap and their Cuff as a wrist strap.
08-29-2018, 02:17 PM   #172
QuoteOriginally posted by rogerstg Quote
Ah ok, thanks for your input!
08-30-2018, 04:36 AM - 1 Like   #173
pxt
Is it really better protection from slide / move after adjustment of lenght?
I think the same. Peak Design after watching video looks as good design. Lifetime guarantee seems atractractive for me.
08-30-2018, 05:58 AM - 2 Likes   #174
TER-OR's Avatar
I have slings from a Kickstarter, they're pretty nice as they're built from car seatbelt material. They're not as comfortable as the Black Rapid but they're very long, so I use them in the winter when I have a jacket on anyway. I gave one to my Dad who still coaches soccer and hikes in his mid-70s. The sling lets him keep his hands more free.
You'll figure out what's best for you, and it may not be a single solution.
08-30-2018, 10:59 AM   #175
rogerstg's Avatar
I'm not sure I understand your question, but I was comparing the security of the Peak Lite strap to the security of a simple strap hung by one lug. The Peak strap uses two attachment points, causing a tele lens to stay against my body, vs a tendency for the camera/lens to twist more with a simple strap. Also, the Peak strap has a rubberized coating on one side. It's a simple matter to flip the strap at my shoulder to temporarily keep the camera from sliding. For example, when my granddaughter ran up to me at her birthday party, I simply slid the camera behind me as I flipped the strap at the shoulder (so the anti slip coating contacted my shirt), and bent to pick her up as she got to me. My old system usually required me to hold the camera with my right hand to prevent it swinging forward from my backside when bending forward.
I hope this helps.
08-30-2018, 11:20 AM   #176
pxt
Yes, it is what I ask for. I simple was afraid that this strap has tendency to swinging few mm. Advertise and reality sometimes are diffrent...
08-30-2018, 12:31 PM   #177
If You want something more pro, then K10D. If something smaller, then K200D or K-m. All of them have SR and nice CCD sensor, but the first two have in addition weather sealing, which is very good For manual focus with old lenses these cameras are great.
08-30-2018, 01:58 PM   #178
jack002's Avatar
Yeah, I've been having a great time with it!
I've skimmed through the manual a couple times, but have yet to read it fully.
And yeah, the K-5 looks like it's great for the money! Hopefully I can keep most of my stuff cost-effective
Any suggestions for my K-5? Things you wish you knew about when you first got it or stuff like that?
Nothing of note. I wanted to use my manual lenses, so knowing how to set it to do that was important. Get to know where everything is. I don't worry with white balance now, I can set that in post. Get it to make raw files, with or without the JPGS.
I keep a battery charged all the time to swap if I run out of power.
I never got into 'back focus' where you auto focus with the AF button on the back, I use manual mode a lot, not a lot of fast moving subjects for me most times.
Get familiar with how to change aperture, shutter speed, iso, and the built in flash has a way to turn down the brightness.
I never got into the user settings for user mode.
Good luck. Keep us up on how you like it and things you're doing with it.
08-31-2018, 07:51 AM   #179
jack002's Avatar
This is the link to how to use a manual focus lens
Using Manual Lenses (M42 Screwmount, M , K) on Pentax DSLRs F-- - PentaxForums.com
*ist, beginner, budget, budget dslr, camera, compatibility, da, da*, dslr, fa, focus, iso, k-5, k-mount, k-x, k1000, k10d, lens, lenses, night & low light, noise, pentax, phone, photography, pm, sensors, series, suggestion
Newbie Armature, Newbie to Pentax jgirl57 Welcomes and Introductions 5 08-31-2014 09:31 AM
Newbie - Wedding Lens setup? (on a budget) robertbrown_ Pentax SLR Lens Discussion 18 08-11-2013 09:58 PM
K-r or K-5 as first DSLR, limited budget tobinobin Troubleshooting and Beginner Help 30 03-20-2013 01:45 PM
Newbie (on a budget)'s first flash Ben E Flashes, Lighting, and Studio 13 07-09-2011 11:49 PM
Trashy Studio Lighting/Backdrop on a Budget - decent results! Ryan Trevisol Photographic Technique 3 06-22-2011 07:49 PM
All times are GMT -7. The time now is 08:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
