Originally posted by axl I have CS3. I have tried to use it's B&W filter presets, but I'm finding it difficult. The shots end up looking more like watercolour painting then like a digital image. Any ideas?
I tend to use different B&W conversions for different photos. Depends on what I want out of it. One of my most used for CS3 is the light channel lab method.
1) In CS3 Image/Mode/Lab color
2) In the Channels Palette click on the light channel, then go back and do Image/Mode/greyscale
3) Create a curves layer but don't do anything with it, just click on okay. Go to the blending menu and choose Multiply if it's to light (normally the case) or screen if it's to dark. Use the Opacity slider until it looks about right.
It's still likely going to look a bit flat so create another curves layer. A nice S curve usually does the trick, but you can play with it till it looks right.
the nice thing about using the light channel from lab is that you don't run into any of the noise problems that can come up using the B&W mixer in lightroom or the channel mixer. It also does a much better job of preserving subtle tones in the highlights. It doesn't work for every photo but I use it about 80% of the time. You can make a action for it that makes it very easy.
