Originally posted by DeadJohn I think the OP wants to know about the combined low pass filter (if present, aka antialiasing filter) plus IR cut filter. Pentax DSLRs without low pass still have the IR cut filter.
Anecdotally, when doing astrophotography I notice that my K-1 blocks hydrogen-alpha 656mm much less aggressively than the K-5 does.
Yep, that's exactly what I am looking for.
Originally posted by stevebrot All but the K-5 and K-5II don't have low-pass filters.
They do, but to cut UV and IR only or else they would be giving full spectrum images.
Originally posted by Bob 256 I can't help on the ones you have listed but I posted the transmission for the K-01 bandpass (UV/IR cut) filter (post #5) which should be similar to the ones you listed. There could be some variation at the wavelengths you mentioned due to manufacturing differences.
UV/Haze filters - PentaxForums.com THanks! Now if I could only get those for the listed cameras. Basically I want to do another astro camera to go along with what I am using, my K1, K3, and full spectrum K-01.
