Originally posted by Thesorus The camera did not start but the batteries indicator showed full, but there was nothing else displayed, the motor for the lens was working (40mm ltd), the shutter seemed to be working. but nothing else.
This clearly indicates the system hung during the initializing process.
This can be caused by
- a faulty bit in the ROM code
- a component's answer does not fit to the answers allowed by the programmers, and the answer (or lack of) was not captured by a fault message or time catch.
The more likely 2nd possibility can be caused by:
- battery problems (one or more cells low, or bad contact)
- communication problems with an attached lens.
- problems in initializing the SD card interface
- contact problem of the micro switch controlling the SD card door (falsely signalling the door is open)
- a button hanging
- The mode wheel not fully engaged at a valid position
- other internal hardware problems, as screw drive, sensor (dust removal at start-up), and many others.
Clean all contacts of the batteries, the battery compartment, and the lens mount.
Remove the SD card, clean the contacts, and put it in again. If possible, also try another card.
The advice by
Belcik (post #3) is never wrong. And if, after following his advice, you are able to get to the menue, make a full reset. You will have to re-do all your personal settings, but if the camera stays dead, this would not matter anyway.
