1) Thanks guys, I knew that I came to the right place
2) It doesn't matter, because I'm going to win the K1ii tonight!
I'm not sure exactly how to post EXIF or how much is really useful, but shot #2 was Tav mode (spot metered) and I changed it to M mode and moved the aperture to 1.7.
Shutter speed was 1/30th and ISO was 400 on both shots. f1.7 on the first shot / f2 on the second shot.
there was lamp behind the guitar and some overhead LED lighting in the room. The reason I did this is because it was significantly under-exposing wide open. I wanted to see what happened if I properly exposed and then only opened aperture.
Here's full EXIF for the first photo:
- X-Resolution - 240 dpi
- Y-Resolution - 240 dpi
- Software - Adobe Photoshop Lightroom 6.14 (Windows)
- Date and Time (Modified) - 2018:08:31 15:44:30
- ISO Speed - 400
- Exif Version - 0230
- Date and Time (Original) - 2018:08:31 11:57:14
- Date and Time (Digitized) - 2018:08:31 11:57:14
- Exposure Bias - 0 EV
- Metering Mode - Spot
- Color Space - sRGB
- Focal Plane X-Resolution - 2079.219971
- Focal Plane Y-Resolution - 2079.219971
- Focal Plane Resolution Unit - cm
- Sensing Method - One-chip color area
- Custom Rendered - Normal
- Exposure Mode - Manual
- White Balance - Auto
- Focal Length (35mm format) - 75 mm
- Scene Capture Type - Standard
- Contrast - High
- Saturation - Normal
- Sharpness - Hard
- Subject Distance Range - Close
- Lens Info - 50mm f/1.7
- Lens Model - smc PENTAX-F 50mm F1.7
- Compression - JPEG (old-style)
- Thumbnail Offset - 830
- Thumbnail Length - 10144
- Displayed Units X - inches
- Displayed Units Y - inches
- Photoshop Thumbnail - (Binary data 10144 bytes, use -b option to extract)
- IPTCDigest - e9ee0f8db7f316974f058bba03c06993
- Coded Character Set - UTF8
- Application Record Version - 4
- Date Created - 2018:08:31
- Time Created - 11:57:14
- Digital Creation Date - 2018:08:31
- Digital Creation Time - 11:57:14
- Viewing Cond Illuminant - 19.6445 20.3718 16.8089
- Viewing Cond Surround - 3.92889 4.07439 3.36179
- Viewing Conditions Illuminant Type - D50
- Measurement Observer - CIE 1931
- Measurement Backing - 0 0 0
- Measurement Geometry - Unknown (0)
- Measurement Flare - 0.999%
- Measurement Illuminant - D65
- XMPToolkit - Adobe XMP Core 5.6-c128 79.159124, 2016/03/18-14:01:55
- Creator Tool - Adobe Photoshop Lightroom 6.14 (Windows)
- Metadata Date - 2018:08:31 15:44:30-07:00
- Lens ID - 3 33
- Document ID - xmp.did:de872abf-9bd3-2449-a147-9bacb55b8899
- Original Document ID - 2CF83E60B1CEB55BE58C15CA52CAF0CF
- Instance ID - xmp.iid:de872abf-9bd3-2449-a147-9bacb55b8899
- History Action - derived
- History Parameters - converted from image/dng to image/jpeg, saved to new location
- History Instance ID - xmp.iid:de872abf-9bd3-2449-a147-9bacb55b8899
- History When - 2018:08:31 15:44:30-07:00
- History Software Agent - Adobe Photoshop Lightroom 6.14 (Windows)
- History Changed - /
- Derived From Document ID - 2CF83E60B1CEB55BE58C15CA52CAF0CF
- Derived From Original Document ID - 2CF83E60B1CEB55BE58C15CA52CAF0CF
- Format - image/jpeg
- DCTEncode Version - 100
- APP14 Flags0 - [14], Encoded with Blend=1 downsampling
- APP14 Flags1 - (none)
- Color Transform - YCbCr
- Camera ID - 72157631866529417
- Camera Type - Digital SLR
and here it is for the 2nd photo:
- Make - PENTAX
- ISO Speed - 400
- Date and Time (Original) - 2018:08:31 11:56:55
- Date and Time (Digitized) - 2018:08:31 11:56:55
- Exposure Mode - Auto
- Contrast - High
- Sharpness - Hard
- Thumbnail Length - 10344
- Photoshop Thumbnail - (Binary data 10344 bytes, use -b option to extract)
- IPTCDigest - 2b2510772ee695c4b163f82b803c31d8
- Time Created - 11:56:55
- Digital Creation Time - 11:56:55
- Lens ID - 3 33
- Document ID - xmp.did:027c547c-4dfe-2c46-b9cb-4fb627843413
- Original Document ID - 11D03E18E0E07E8A5531F980E78FA889
- Instance ID - xmp.iid:027c547c-4dfe-2c46-b9cb-4fb627843413
- History Instance ID - xmp.iid:027c547c-4dfe-2c46-b9cb-4fb627843413
- Derived From Document ID - 11D03E18E0E07E8A5531F980E78FA889
- Derived From Original Document ID - 11D03E18E0E07E8A5531F980E78FA889
