I bought a K100D a little over a year ago as my first DSLR. I've liked it a lot, and it worked well for me as a dabbling hobbyist/newb. In the past couple days, though, I've run into a problem:
When I turn on the unit, it will initially work fine for a few shots. Then it will seem to kinda.. freak out. The LCD will stop updating, and the shutter will no longer fire. If I turn the camera off and then back on, the LCD will not come back on, but after a few seconds *some* of the appropriate data will show on the top display, but not all -- for example, the available picture count for the SDCard does not show. Also, when I first turn on the unit, it will make a dull, quiet double-clicking noise that is not present when it works normally.
*Sometimes*, if I pull the SDCard or batteries, it will return the camera to normal. Not always, though. I've been unable to determine a particular action that causes this, and changing batteries, lenses, and SDCards doesn't seem to make a difference.
Update: I've found that the unit will just *lock up*, and go into the "problem" mode I'm having, even if I'm just sitting in the menu system. Pulling the SDCard for a few seconds and re-inserting after powering off does seem to fix the issue pretty consistently, if only for a few minutes.
Any thoughts on this, other than to ship it back for repair? I have a family trip to Disneyworld in three days, so if I do send it, I'll not have the camera at all, and with it working intermittently, I'm a little reluctant to give up completely.
Thanks in advance for any advice you can offer!
-Ed
