Do you
need - or do you
want - another camera?
I ask because my recommendations would be different depending on your soul-searched answer to that
If you truly
need another one, then I'd probably go with the K-1 or K-1II. It gives you a wider field of view for your 70-200, and the full-frame body will open up a whole bunch of new possibilities for you. Plus, you can switch it to APS-C mode and get extremely good quality shots in that format... not at quite the same resolution, of course, as a KP - but the resulting files will be more than detailed enough and reproducible at large sizes. And, whilst the continuous shooting frame rate of the K-1 & K-1II is slower than its APS-C stablemates, the buffer is much deeper.
If, however, you only really
want another body and can afford to hold off for a while, I'd wait to see what 2019 brings. There's a possibility we might see a replacement for the K-3II, and I believe that will be a special camera. It's likely to have at least the same features (we hope) as - and possibly more than - the K-3II, whilst improving still further on the KP's image quality, and with incrementally (or perhaps considerably) improved AF. In the mean-time, you could add a fast 28-70 (ish) lens to your collection to give you something less wide for the far end. You can do this cheaply, and for little weight, with a Tamron 28-75 f/2.8 (my go-to lens on APS-C), or go for the premium Pentax 28-70 f/2.8. Either will sell quite easily should you ever decide not to keep them
