Originally posted by NickTent
Sunday I tried the dust removal and sensor clean up and I think It has gone now
I assume you mean the Dust Removal setting (settings menu 4). That's the clunk you get when you start up or shut down the camera. Worth leaving it on so it operates each time.
But remember that the dust bunny will still be floating around in the mirror box, so sooner or later it will probably be back on the sensor. As people have said, you should definitely get a rocket blower like this:
https://www.amazon.com/Giottos-AA1900-Rocket-Blaster-Large/dp/B00017LSPI?tag=pentaxforums-20& To use it, you use the Sensor Cleaning in setting menu 4. The procedure is described in the camera's manual at p.120. You should do this as soon as you detect a spot on the sensor because over time dust motes tend to stick to the sensor due to moisture in the air.
Most of the time that works. If it doesn't you need to use a gel stick like the one Paul mentioned or wet cleaning (with specially designed swabs and solution). Those procedures require care because you can scratch the coating on the sensor. Lots of threads about how to do this.
