09-24-2008, 01:26 PM   #1
RaduA
Guest
Pictures of K-m+DA21 and compared to other cameras
Hi,
I probably should of posted this days ago but ... here we go . In case some of you wonder about a size comparation between a K-m+DA21, a Fujifilm S5800 bridge camera and the K100D + kit lens. Also there are higer res version available.
k_m.jpg - File Shared from Box.net - Free Online File Storage
left_K_m.jpg - File Shared from Box.net - Free Online File Storage
Regards,
Radu
09-24-2008, 02:05 PM   #2
wildboar's Avatar
That is a much bigger difference in size than I was expecting (especially compared to the K100). I guess I know what I'm buying myself for Christmas this year...
09-24-2008, 02:22 PM   #3
Busiko
Guest
K20D x K2000
QuoteOriginally posted by RaduA Quote
Hi,
Regards,
Radu
QuoteOriginally posted by wildboar Quote
Compare: K2000 x K20D back to back
09-24-2008, 04:07 PM   #4
Kei
The first pic is the most useful for me as I happen to have a fuji s5700 (same size as the s5800). That really put things into perspective.
My guess the K-m is about the size of the Nikon D40/D60. I hope the K-m is as sturdy as its bigger brothers.
09-24-2008, 04:10 PM   #5
doesn't look much smaller to me. and it's def not much lighter :S
so i guess it should be even sturdier :/
KM
625g (22.0oz.)
With and alkaline batteries SD card
K200D
690g (24.3oz.)
With lithium batteries and SD card
K100D
660 g (1.5 lb)
(reduced by approx. 20 g if using CR-V3 batteries)
09-24-2008, 04:56 PM   #6
RaduA
Guest
I must say that with the DA21 the camera seemed very well balanced. I have larger than average hands and I had a very good grip on it with 3 fingers wraped on the body and the pinky beneath it. In this combo you're looking at about 850 grams with NiMH accus.
2 more things: I used extensively the camera for 4 days (hundred of photos, a lot of menu usage on the LCD, about 50 flash photos as well) and the battery metter never fell a single line. I had 4 great 2700mAh accus in it and I strongly feel that I could go well over 1K photos on a single charge.
The transfer rate was superior to that reported by dpreview for the K200D. I transfered 141 files (dngs and some jpegs) of a total size of 1,35 GB in 164 seconds. That means aproximately 8,43 MB/sec.
Regards,
Radu
09-24-2008, 08:43 PM   #7
architorture's Avatar
these are good to see, but the angles are a little not-useful. the foreshortening in both accentuates the size of the k200d vs. the others. that's why sites like dpreview do these with the more boring straight-on type of shot.
still much appreciated though!
09-25-2008, 01:49 AM   #8
Busiko
Guest
QuoteOriginally posted by architorture Quote
NO foreshortening here. The farther is shorter, not the closer one.
09-25-2008, 02:20 AM   #9
that back to back shot shows that the Km is not quite as wide as the k20. about an inch less maybe. it seems to have the same depth though. I dont think size should be a concern to someone purchasing the KM vs. something like the k200 or the k20. its not THAT much smaller, and as soon as you strap a DA* lens on it, it doesnt matter. neither camera is pocketable. a k20 with a pancake lens can be carried in a woman's purse just as easily as a KM i would guess
09-25-2008, 01:31 PM   #10
QuoteOriginally posted by Busiko Quote
i'm talking about the effects of perspective. closer objects appear larger than farther objects even if they were the same size - so if the farther object is actually smaller, the closer one will seem bigger than it is if the mind compares the two.
Image:Perspective-foreshortening.svg - Wikimedia Commons in fig b the top and bottom of the cube are the same size, but the bottom one looks smaller/the top one looks bigger.
anyway, a true orthogonal view is impossible with a camera, we can only approximate with very long telephoto lens.
camera, da21, dslr, k-m, photography, storage
Webcams: sometimes the lowest quality cameras can take the best pictures Cannikin Photographic Technique 2 10-27-2010 05:00 AM
I've seen the K-7 compared to a wide range of cameras. NothingInCommon Pentax News and Rumors 48 05-21-2009 02:46 PM
DA*16-50 vs DA21 Ltd dugrant153 Pentax SLR Lens Discussion 9 03-01-2009 11:15 AM
Three screw mount cameras compared Nesster Pentax Film SLR Discussion 11 10-30-2008 03:27 PM
All times are GMT -7. The time now is 06:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
