09-28-2008, 06:50 PM   #31
Otis Memorial Pentaxian
I told you so...
Just for the record, I warned against opening the DOF can of worms. If there is anything more confusing than explaining what determines perspective, it is explaining the intricacies of depth of field. Now the worms are loose...
BTW...Six months ago I was a firm believer that wide-angle lenses would give you exaggerated perspective and greater DOF as a property of the optics. Based on the challenge of some forum members, I set up the test images and proved myself wrong on both counts.
09-28-2008, 07:06 PM   #32
Wheatfield's Avatar
QuoteOriginally posted by baw Quote
I'm fine with a statement like: For a given FOV DOF is the same for different focal lengths. At least it seems to be so.
My point is that the article clearly implies that DOF is independant of focal length, which is nonsense.
I'm a bit surprised by this article. I had a high regard for Luminous Landscape....
Depth of field is a relationship between the size of the aperture and the reproduction ratio, nothing more.
Focal length is not part of the relationship.
And Steve, yer welcome...
09-28-2008, 07:16 PM   #33
In case anyone is interested, here is a link to the other thread where all of this stuff was discussed in detail a few months ago:
https://www.pentaxforums.com/forums/general-pentax-photography/30632-85mm-vs-...ification.html
09-29-2008, 01:51 AM   #34
baw
DOF
Seems you have invented a whole new defintion of DOF. Perhaps you can explain what the relationship is. It's also unclear to me what you mean with reproduction ratio.
DOF is normally defined as a range of distances in front of the lens within which objects are reproduced ACCEPTABLY sharp in the resulting image.
See this page with a number of similar definitions and references.
09-29-2008, 02:29 AM   #35
One was taken with a Sigma 105mm macro at about 2 to 3 feet.
One was taken with a 560mm astro scope barlowed to an effective FL of 1100mm (about 30x magnification) with extensions to move focus closer. About 25 feet or so.
Can you tell which is which?
50mm, camera, change, crop, dslr, fov, lens, perspective, photography, photos
Equivalent FoV icypepsi Pentax DSLR Discussion 42 10-28-2010 12:34 AM
645 fov lbenac Pentax Medium Format 5 04-26-2010 12:11 PM
DOF and FOV calculator MoiVous Pentax SLR Lens Discussion 2 05-31-2009 10:52 PM
FOV compare 21Ltd to 31Ltd Eaglerapids Pentax SLR Lens Discussion 29 04-10-2009 05:14 AM
Focal lengths FOV roy Pentax SLR Lens Discussion 4 03-08-2007 08:35 PM
All times are GMT -7. The time now is 10:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
