Originally posted by kunik Nice job on the fix up.
Indeed, especially seeing the starting point was a pretty low resolution JPEG.
Quote: What I meant was I did all I could "IN CAMERA" to save the photo. Shooting a 300mm at F2.8; at 1/60; and at ISO1600 (PP +1). Post processing further can fix all sorts of problems but I prefer to spend more time shooting and less time in photoshop.
OK, but I assume by PP + 1 you mean you pushed it a stop in ACR. In which case, also applying a little NR an perhaps a curve wouldn't take that much longer - especially if you create a present to do all of those for you, and then you can batch apply it to as many images as you like in a matter of seconds.
I would note that the image I posted didn't look like that straight from the camera either, nor do most of really impressive high ISO images you might see posted. And apparently, neither did yours, as you pushed it a stop in PP.
