11-24-2018, 05:56 AM   #1
Frontfocus after upgrade k1 to K1II
Hi, I received my Upgraded k1II, inmediatly I notice a frontfocus with my FA 20 2.8 , I have done test with many on my lens and I can say there is a -6 frontfocus in most of them . Anybody notice some issue after upgrade.?
is this issue covered by warranty?
thanks
11-24-2018, 06:23 AM   #2
It sounds normal to me, you'd expect to have to fine tune autofocus for the new camera. It's within the adjustment range. My k3ii had on average +6 before going for repairs two years ago, and now it's more around +3 if I remember correctly, so even service adjustments on one camera will require re-calibration.
11-24-2018, 07:42 AM   #3
UncleVanya's Avatar
QuoteOriginally posted by aaacb Quote
If I'm reading the post right this was the same camera, a k1 that was upgraded to a k1mkii. Given that no mount work is done, no sensor work is done, it does seem odd that this changed.
What was the repair on your k3ii?
11-24-2018, 08:42 AM   #4
I missed the part that this was an upgrade.
For mine, the mode dial was broken, the repair shop was precision. The reason AF fine tune changed was because they included a CLA, which I guess includes adjusting the AF sensor. I'd assume the upgrade also includes some similar adjustment.
11-24-2018, 08:43 AM   #5
This seems odd. I checked several lenses before and after the K-1 to K-1ii upgrade and observed no change. However they do check the AF calibration so maybe yours needed adjustment.
11-24-2018, 12:36 PM   #6
The board replacement resets all settings, so if you had any fine adjustments before, they would need to be re-entered.
11-24-2018, 03:47 PM   #7
Otis Memorial Pentaxian
This ^ ^ ^
And given that the upgrade included changes to the AF system, one would expect changes to behavior there as well. It is always possible that the AF system calibration from the upgrade was not proper.
QuoteOriginally posted by pasorro Quote
If you feel that the global AF settings were poorly calibrated with the upgrade, you might want to take the matter up with Ricoh and/or the company that did the upgrade.
camera, dslr, frontfocus, issue, k1ii, notice, photography
K1 to K1ii upgrade, still waiting on full review to decide garywakeling Pentax DSLR Discussion 8 09-05-2018 08:09 PM
Is K1ii better than K1 for capturing moving subjects? Billk Pentax K-1 12 06-01-2018 11:34 AM
What causes backfocus or frontfocus? yusuf Pentax SLR Lens Discussion 19 06-08-2012 03:44 PM
K20d + Sigma 50mm 1.4: frontfocus only at large apertures chrisg Pentax DSLR Discussion 15 10-30-2009 08:03 AM
Backfocus/frontfocus on K10d? dresden_phoenix Pentax DSLR Discussion 13 05-02-2008 01:06 AM
All times are GMT -7. The time now is 01:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
