Originally posted by Spodeworld I'm struggling with the thought of getting a KP as I have a K3....wondering if on balance it's really a worthwhile move (esp as I'be been waiting for a true K3(II) upgrade). I love the idea of the better High ISO image quality, 5-axis stabilization, better AF and tilt screen, but wondering about some of the features it's missing (which I'd miss but don't seem as important as the advantages mentioned).....hmmm...maybe I'm starting to tilt.....
You will definitely like tilting with the rear screen! Very useful for shooting from low or high positions. Nothing wrong with having a K-3 and a KP. And/or a KP and K-1 as well. Each has its own advantages. I have the KP (now 2 of them) but still have and like my K-5 IIs. It has similar advantages to the K-3 except for the 2-card slots, which I would not use anyway. So for a deeper buffer (I rarely do much burst shooting), or when I need its excellent on-body controls set for quick changes, its battery grip which can take AA lithiums in a pinch, balance with bigger lenses, etc. etc. I do not hesitate to employ my older camera. Not bad at higher ISO either, has very good DR, and still delivers impressive imaging. But for most uses, and certainly for low light or otherwise needing higher ISO for shutter speeds, for better compactness for portability, top-notch IQ, better SR, even better AF, I love my KP!
Although I do like the top LCD panel, and have been used to that for years, I soon got used to being without one with my little KS-2, and then the KP, which somehow is better. As I say, the controls aren't as good as my K-5 IIs, but far better than the K-S2/K-70 style. On my K-5 IIs, for instance, I switch metering to spot, etc. quickly with a handy lever. Not quite as handy, but still pretty quick, doing the same via the 2 extra top dial knobs is handy enough. The AE-L button is dual-use also as a back AF button. But I leave it set to AE-L because I do use this feature with some frequency, and the shutter button half-press is what I generally use for AF anyway. So there are some things to get used to, but the KP is definitely more advanced over a K-70 in practically every way, and has both compact-practical and performance advantages over its larger relatives.
As to battery life, I keep a spare in the front accessory pocket of my camera holster-type belt pack, along with the little DA 15mm Limited and some SD cards, etc. I also have the KP's battery grip, which can provide immense battery life, in addition to a much larger gripping surface and balance for larger lenses, and at about the same total weight as a K-3 II.
