Thanks for the replies.
I'm fairly certain I will not have any opportunities to use a tripod. I was considering trying to get a monopod in, but being government buildings I'm fairly certain a carbon fiber mace would be off limits.
So likely I won't be able to use Pixel shift (unless it's hand-held, which I understand is not recommended).
I did consider the improved SR. That's standing out as the biggest improvement on the K-1 vs the K-5IIs.
---------- Post added 11-30-2018 at 04:52 AM ----------
Originally posted by clackers Sensor wise, the IQ's pretty much identical, MV, you shouldn't notice the 1Mp or so difference.
The K-1 body itself will move the sensor five ways for stabilizing handheld shots, supports electronic shutter on a tripod to reduce shock and pixel shift.
Both do composition adjustment so you'll be able to get away a bit with tilting the camera up to a building.
Also in my arsenal of lenses is a 35mm tilt and shift lens. If I could use a tripod I'd certainly get the most out of the K-1.
Btw, the reason I never upgraded to the K-3II over the K-5IIs is I use composition adjust all the time and pentax removed the RAW/FX quick menu option of composition adjust from the K-3II. The IQ on the K-5IIs is good enough that little stuff like that kept me from upgrading.
