Originally posted by GUB Ok here is the same background done with a ruler. It was slightly sunnier with the K01 shot. (as if there wasn't enough variables already!)Ex camera jpgs. Note the purple in the lower right. That is some flowers about 700mm away. Almost no difference in the blur of them. I think this is about as objective as you can get comparing the bokehs.
That is great comparision shot. As you can clearly see the difference.
If you look at that tree(?) at left. with aps-c it is only half in frame. and with FF it is more at middle and you can see the whole trunk(or shape of it). To my eye there is big difference. But bokeh vise not so much, or if you count in all the things that you can see then there is much more. It is all about one's taste
edit. also numbers look bigger in FF picture
but that is part of the deal, when you 'match' the FoV.
