12-30-2018, 12:57 AM   #31
Yup, I believe that difference comes when you are focusing little further away than MTF.
12-30-2018, 03:51 AM   #32
GUB
GUB's Avatar
You have got me with "MTF" ?
12-30-2018, 06:26 PM   #33
GUB
GUB's Avatar
If you want to test an idea then take it to its extreme.
So I fire up the Pentax Q original with the SMC Tak 50mm f4 wide open and recreate the layout of the post #16. (Edited )
The Q sensor is 4.5mm high compared to the K1 24mm
So from what I can see -in a closeup set up (and maybe all) for a given lens and fstop and a given subject magnification all sensor formats will end up with a similar oof bokeh.
This is of course complicated by the effect of FOV.
Please note - the Q is cruel and unusual treatment of old lenses. Due to the image magnification required the Q is essentially presenting the lens at 1/5 of its resolution compared to using FF.
12-30-2018, 10:28 PM   #34
QuoteOriginally posted by GUB Quote
Oops! I ment MFD...sorry MTF is something else..
12-30-2018, 11:27 PM - 1 Like   #35
dbs
Hi GUB
That Q shot looks a bit "dreamy" but still fine......on a 15 inch laptop anyway
What away to spend christmas though..keeps the troops entertained
Dave
12-31-2018, 12:57 AM   #36
GUB
GUB's Avatar
QuoteOriginally posted by dbs Quote
Hi GUB
Dave
Hi Dave
I am stuck on the farm keeping it ticking over so this stuff is great procrastination material rather then going out and doing some work. With the added bonus of teaching myself something at the same time.
12-31-2018, 01:06 AM   #37
dbs
Hi GUB
The break before/after harvest
Happy New Year
Dave
12-31-2018, 01:08 AM   #38
GUB
GUB's Avatar
Hi GUB
Happy New Year
Dave
Bull beef farm here - the bulls do the harvesting! I just try and control the mess!
01-01-2019, 08:07 PM   #39
pentax360's Avatar
Interesting.
01-02-2019, 03:41 AM   #40
Not a Number's Avatar
From what I've been reading a smaller sensor should generally give a shallower depth of field. The main reason being the pixel size of the sensor. Pixel size affects the circle of confusion (COC) which in turn affects the perceived DOF.
Changing magnification changes the focusing distance which in turn changes the relationship of the distance of the lens/image plane to the background which changes how out of focus the background is.
Using this online calculator you can easily see the relationships between COC magnification and focusing distance. Note due to the numeric precision the calculator "breaks" from divide by zero errors of which there is no error trap other than not updating values on the display.
Lens Magnification and Depth of Field Calculator – kielia.de
For instance using a (min focus distance taken from 50mm f/1.7 Pentax-A) at f16:
extension = 0mm
focusing distance = 0.450m
magnification = 0.15
DOFCOC in mm ) in meters:
FF (0.029) = 0.477-0.427 = 0.050
Crop (0.019) = 0.467-0.434 = 0.033
extension=25mm
focusing distance = 0.210m
magnification = 0.65
DOF
FF = 0.212-0.208 = 0.004
Crop = 0.211-0.209 = 0.002 (2mm!)
That's why I suggested mounting the camera on a tripod and keeping the subject to sensor constant using the same lens on a FF vs Crop body. The difference in DOF and bokeh would be due mainly to COC and pixel size/density differences.
By changing the magnification as you are doing you are introducing other changes such as subject and background distance to image sensor. By magnification I am using it in the sense as defined for macro photography - the ratio of the object size vs the image size on the sensor plane. At 1 magnification a 10 mm object would have a 10 mm image on the sensor. Thus with the images with the scale or ruler in them at 1 FF would show 24mm top to bottom vs 15.6mm for crop.
Of course all this is leading down the road of "equivalency" of crop vs FF which maybe we don't want to go there. Then again such experiments as these might give us a better understanding.
01-02-2019, 05:06 AM   #41
Dartmoor Dave's Avatar
I know this was originally about bokeh specifically, but the conversation does seem to have widened out to discussing depth of field in general. So perhaps it would be useful to have a couple of comparison shots showing the difference in front-to-back depth of field between the two formats at smaller apertures? That will actually be more revealing of the real impact of sensor size than subjective preferences about bokeh could ever be. And after all, traditionally the main concern involving depth of field was about how much apparent front-to-back sharpness you could get, and that's certainly still my own priority.
As Not a Number says though, let's please not fall down the rabbit hole of "equivalence". That way lies madness.
01-02-2019, 05:49 AM   #42
Lowell Goudge's Avatar
Lens Magnification and Depth of Field Calculator kielia.de
extension = 0mm
extension=25mm
DOF
But you forget, the discussion about CofC ties back to final magnification of the image, and if you shoot with the same lens on 2 different formats from the same distance the bokeh and DOF are the same, because you crop and enlarge both exactly the same at the end.
The issue is about perspective of different formats leading to different bokeh with the same lens when you force the shooting distance to change
01-02-2019, 12:25 PM   #43
GUB
GUB's Avatar
Definitely the smaller format (or large format further back from subject and cropped back to same magnification of subject) with the same lens at the same fstop will have greater dof - that is well established.
What surprised me is the bokeh effect doesn't follow this trend.
About the only way to objectively measure bokeh is the size of the bokeh balls. If you compare the various matched sets above you can see the bokeh balls have stayed the same approximate size.
01-02-2019, 01:58 PM - 1 Like   #44
Insanely humble
savoche's Avatar
The difference in Dof surprised me too. Suddenly those nice closeup bokeh shots taken wide open were that much harder to get right - to the extent that I have felt the need to stop down a bit which kind of takes away the point of having the nice old fast glass like the 50 1.4s.. And only now have I realised that I was not getting the presumed gain of a smoother bokeh.
Don't get me wrong - every thing else with the old glass on the K1 is superb.
Yes, a lot of people rave about "DoF control" as if thinner depth of field is always better. Sure, you can stop down to increase the depth, but that quickly introduces hexagons in a bokeh that might not be any smoother to begin with. Or you can pick a slower lens. But then your "DoF control" is getting rather cumbersome.
So the conclusion is still the same; every sensor size comes with a set of compromises. Bigger is not always better. That said, 9 out of 10 times I'd choose the K-1 over any other camera I own
01-02-2019, 02:42 PM   #45
GUB
GUB's Avatar
I think what I am showing is not the perspective differences but rather the application of the bokeh ball on that oof background.
The small fov background will tend to be simpler in most situations. But not necessarily so if the telescopic effect enlarges what was tiny details in the wideangle view.
I visualise the size of the bokeh ball as the size of the paint brush painting that oof background.
In these setups the bokeh ball size seems to remain constant.
aperture, apsc, background, bokeh, bokeh vs k10, camera, depth, depth of field, dof, dslr, ff, field, fov, k1 bokeh vs, k10, lens, photography, post, shot, subject, vs k10 apsc
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 2 06-28-2017 04:59 PM
Pentax KP vs. D750 raws at high ISO 25600 - Pentax APSC on par with Nikon FF beholder3 Pentax News and Rumors 72 03-01-2017 02:30 PM
How many APSC shooters will truly upgrade to K1 sumitkar1971 Pentax DSLR Discussion 347 06-25-2016 12:29 PM
Enthusiast vs Prosumer vs Semi Pro vs Pro vs APSC vs Full Frame mickyd Pentax DSLR Discussion 10 11-12-2013 07:14 PM
Misc 100mm f/2.8 Macro WR Bokeh Bokeh Bokeh! iocchelli Post Your Photos! 3 03-20-2011 02:22 AM
All times are GMT -7. The time now is 06:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
